C63/C63S AMG
Battery Tender Question
Old Aug 8, 2022 | 02:46 AM
mokawop's Avatar
c450
I was wondering if the battery charger I linked below would work for the c63? I am pretty sure it's compatible but I just wanted to make sure. Thanks!
Amazon Amazon
Old Aug 8, 2022 | 04:10 AM
Fordgt40's Avatar
C63 amg esate
https://www.amazon.com/CTEK-56-926-L.../dp/B00EUF6UM8
Not sure, isn’t it just for lithium batteries, I use a CTEK MXS 5.0 on mine which is fine for C63 AGM battery.
Old Aug 8, 2022 | 09:12 AM
Star4life's Avatar
2017 C43 AMG
I would buy a higher model ctek which has more than just lithium capability. or buy a NOCO charger. All of the noco chargers can now do all types of battery. This way you can charge lithium batteries and standard batteries with same charger.
Old Aug 8, 2022 | 10:07 AM
Shreddie's Avatar
C63S Sedan
Rocking a NOCO right now - seems to do the job just fine.
Old Aug 8, 2022 | 11:14 AM
AMG82's Avatar
2020 C63s Coupe
One in your link is for lithium battery. Our cars have AGM battery so you need regular charger.
I use BMW branded CTEK charger that can do both lithium and AGM and that worked great for both C63s (AGM) and M4 (lithium).
As mentioned above, NOCO seems like another good brand you can try.
This one also supports both lithium and AGM.
Amazon Amazon
Old Aug 8, 2022 | 01:12 PM
user33's Avatar
https://www.amazon.com/NOCO-GENIUS10...dp/B07W3QT226/
I've also used this one on a C43 and C63 S (AGM batteries) and a GTR Pro (lithium battery) and various sealed/gel type batteries, all with complete success.
Old Aug 8, 2022 | 03:01 PM
mokawop's Avatar
c450
Do you remember which ctek you had? I am actually trying to charge both a c63 and m3 so I was trying to get the one I linked above. If not I will get the noco one. Thanks!
Old Aug 8, 2022 | 10:50 PM
dctwc63s's Avatar
2019 C63S Sedan
I've been using a ctek multi 3300 for the past 2 years with no issues.
