C63/C63S AMG
20" wheels / tires questions - 2019 C63 Estate
Old Sep 29, 2022 | 05:15 AM
brunosbeard's Avatar
C63 ESTATE
Talking 20" wheels / tires questions - 2019 C63 Estate
Hi all, first time poster and first time AMG owner - thanks for having me!
I recently purchased a 20k miles second hand W205 C63 Estate in beautiful condition, and absolutely love this car. I have some questions about the wheels though....
It came with non-standard 20" rims (I believe they only come with 18 or 19 from the factory?). After 5k miles, the front left started slowly losing pressure. Upon taking it for a replacement tire, the garage showed me that both front tires are heavily worn/split on the inside corners, that this indicates that the wheels needed re-aligning. Also that the front left wheel was cracked (likely due to running over a pothole on our rubbish roads). I've had this crack welded up, but whilst doing the welding a second mechanic commented that in his opinion the wheels themselves are poor quality aftermarkets and consequently I am likely to have more of these problems in future. He recommended getting a better quality set of wheels (if I could afford it), and/or at least moving to 40mm thick tires (currently 30 front & back) to increase protection.
Does anyone have any comments on any of this? Should I be looking at a new set of wheels? I've looked up genuine Mercedes sets which look like they cost upwards of £4-5k including tires!
Should I just get a set of thicker tires, pay for a re-alignment and try to be more careful around potholes?! If so, can I run 40mm tires on 20" rims? Should I spec the same thickness front and back?
Many thanks in advance for any support or advice!
Old Sep 29, 2022 | 07:15 AM
Belong's Avatar
W205 C63S T
get the oem 19inch forged ones.... and get used to the fact that the c63 eat tires on the inside on the fronts...
Old Sep 29, 2022 | 07:37 AM
C63 ESTATE
Thanks - can you point me in the right direction?
Old Sep 29, 2022 | 11:51 AM
superjackson's Avatar
2021 C63S Sedan
Good quality 20" rims aren't easy to bend or crack unless your car fell into a trench sized hole, I recommend you to get better quality rims and new tires.
You can do some research on the width and offsets that are suitable for this car and try to get a set of used high quality (usually forged) aftermarket or oem wheels for 2-3k.
Also, the height of the tire (30) is a percentage, not an actual height in mm. For example if it's 265/30/20, the height of the tire sidewall is 30% of 265mm.
Old Sep 29, 2022 | 12:06 PM
C63 ESTATE
Ah ok, thanks. So I've currently got 245/30ZR20 - does this mean 30% of 245? Is there any way to find out whether, for example, a 245/40ZR20 tire would fit the car?
Old Sep 29, 2022 | 01:21 PM
2021 C63S Sedan
Yep, the height of your tire is 30% of 245. I know that a 245/40ZR20 will most likely not work but 245/35R20 should work.
However, Mercedes setup the car to have the rear tire be at least as tall as the front tire. If you are changing to 245/35R20 front, you should at least use a 275/30R20 or 265/35R20 rear (a little tall, not sure if it fits ).
