C63/C63S AMG
HELP! Curbed my wheel and need advice
Old May 24, 2023 | 11:09 AM
bigbadpaul's Avatar
2017 Mercedes Benz C63 AMG S Coupe
Unhappy HELP! Curbed my wheel and need advice
Hi everyone. I accidentally curbed my front passenger side wheel and need some advice on if I need to get a new tire or not - I am getting the rim fixed so not concerned about that. I got these new summer tires installed about 2 weeks ago and don't drive much so swapping in a single new tire shouldn't be an issue. There is a large chunk of rubber missing from the sidewall, but it appears the chunk of rubber is just the protective lip, so more like cosmetic damage versus structural damage to the side wall. Do I need to replace the tire? Uploaded a few pictures below. Any and all comments would be greatly appreciated.
Thanks!
Old May 24, 2023 | 11:52 AM
E55Greasemonkey's Avatar
This place is a joke.
Generally if you can't see the nylon threads where the sidewall damage is, and there is no bubble, the tire is ok.
Old May 24, 2023 | 06:38 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W205 AMG forum...
Old May 25, 2023 | 10:12 AM
507AMG's Avatar
2017 C63S Coupe
Be prepared for disappointment on the wheel repair. All they are going to do is lathe material off the wheel until the rash is gone. From a distance, it will look ok but close up, it sucks. Biggest issue when they remove material off that area is the nice AMG logo area gets ground down and does not look legit anymore. This is a forged wheel and you cannot add material back to it before putting on on the lathe. Said another way, it will not be the same as the other wheels. For me, that was not OK. Not trying to be negative but I had the wheel and tire package and I insisted they replace the wheel as they needed to put it back the way is was. YMMV
Old May 25, 2023 | 10:59 AM
benzbell's Avatar
2023 Urus Performante 2018 Huracan Perf. - 2017 Ferrari 488 GTB
^^ I can vouch for that. Those repairs suck. They basically just grind off material and blend paint. From a distance it can pass but otherwise not to me. Although some places do a better job then others. No way I'd live with that tire even if there is nothing wrong with it structurally. It stands out pretty good like an unwanted pimple.
Old May 25, 2023 | 12:53 PM
ForMBForum's Avatar
C230/E350/E53/C63s
If your tire isn't losing abnormal amounts of air and you're not regularly pushing really fast speeds/corners then I think mechanically it is okay.
If you really want to replace your rims, you might try seeing how much someone is willing to pay for stock AMG rims, because I know people who don't have AMG's really love them. You could then use that money to buy aftermarket rims and tires.
Old May 27, 2023 | 06:56 AM
Jimmy_c63s's Avatar
Thanks!
Hey Paul your tire is definitely fine and the curb is not even that bad I've done way worse in my coupe taken a big chunk out of my tire deeper than that in the past on the Pilot Super Sports drove on them for a good 10,000 or more miles. That curb rash is an easy fix and will look as good as new if you ever decide to fix it up.
For now you can just wash the car and continue driving it until your next tire change no stress 🙂
Old May 28, 2023 | 07:03 AM
4npower's Avatar
2019 GLC 63, 2020 C43 coupe
Grab a 4-6" file and use the flat smoother side and gently file down all the rough areas on and around the lip, then grab a 500+ grit sandpaper block and go back over it until it is as smooth as you can get it(don't scratch up the tires). It will be hardly noticeable from 20" out. Use a black paint marker to dab any marks on the black surface if you choose.
Old May 28, 2023 | 06:07 PM
W205C43PFL's Avatar
I also heard of products like these
Amazon Amazon
but your method sounds way better
Old May 31, 2023 | 04:41 PM
jig62's Avatar
c63 AMG
repair sucks, you can easily get them replaced!
Old Jun 1, 2023 | 06:05 PM
W205C43PFL's Avatar
Ya but those are nice wheels plus it is not structurally damage I think only cosmetically. I would hate to give up on them so soon.
