C63/C63S AMG
Misfire after downpipe install
Old Oct 28, 2023 | 08:23 PM
BenzAMG99's Avatar
C63s
Hello,
I just finished up today installing catless downpipes on my 17’ c63s. (I had purchased the car already tuned.)
After install, I took the car on a test drive and it was having a really bad misfire + bogging
Plugged in my scanner and it had a few codes, one was cylinder 2 running too rich, and the other two were cylinder misfire in 7 + 8.
I could not pin point the cause, I tried turning the ecu back to stock using the handheld left in the trunk and it did not want to for some other odd reason Lol.
Any idea what I should check on or do, any help is greatly appreciated.
Old Oct 28, 2023 | 11:16 PM
Impasta's Avatar
2021 GLC63s Coupe
You likely have a leak between the turbo and the downpipe or somewhere down the line, did you replace the exhaust clamps?
Old Oct 29, 2023 | 03:50 AM
BenzAMG99's Avatar
C63s
I’ll give that a look again, but no I did not replace the exhaust clamps. I didn’t think it needed to be replaced because they worked fine?
Old Oct 29, 2023 | 12:22 PM
Sazabi's Avatar
2019 C63s
I had my clamps replaced when the downpipes where put on, they have a new updated clamp that can be reused I believe.
Old Oct 30, 2023 | 03:18 AM
Impasta's Avatar
2021 GLC63s Coupe
Yup. exactly. The old clamps leak. Here is the bulletin. https://www.tsbsearch.com/Mercedes-B...07-61-P-073583
Old Oct 30, 2023 | 03:19 AM
Impasta's Avatar
2021 GLC63s Coupe
Yea they have a new one, a two piece. Here is the bulletin. https://www.tsbsearch.com/Mercedes-B...07-61-P-073583
