C63s acceleration issue
After the car comes to a complete stop, sometimes when I press the throttle, the RPM spikes to two or three thousand before there is any power, while at other times the response is very prompt. After coming to a complete stop, the car takes a few seconds after releasing the brake to start moving at low speed, and then the throttle response becomes very prompt again after starting the low-speed movement. The same behaviour happens in both forward and reverse gears.
The dealer said there was a misfire, and they have replaced spark plugs, coils and a fuel injector of the misfire cylinder, but there has been no change. The engine light on the car is not on, and there are no obvious fault codes, only one error code that the dealer told me was the P140473, which should be related to the exhaust valve, but I have seen in other posts that this fault code does not affect performance.
I am wondering if someone can suggest what needs to be checked next step? After doing some investigations online, it seems that the manifold absolute pressure sensors or oil pump can cause this issue. Thanks everyone in advance.
My car does something that I could describe similarly to what you said but idk if its the same as what you're describing. Anyway it's normal with our clutch. On a cold engine and trans (the colder it is the more prominent). The engine rpm rises to around 1800-2300 (I'm completely stationary) before the car finally drops the clutch and I slowly take off. It will even sit there in that rpm range continuously until you push the throttle over the threshold it has to hit. There are times I've been sitting there for 3-5s with the engine cranking just waiting to start moving. Once the car warms up this behavior goes away/becomes nearly imperceptible. Our wet clutch feels closer to a manual trans than to a torque converter auto. I think of it as a driver slipping in a clutch with cold (and not very grabby due to temp) friction material.
One thing I've noticed is that when the symptom occurs and I release the brake to let the car start moving at low speed, the idle sound (not sure if it is from the exhaust) seems to get louder, but the RPM is steady. And when the car comes to a full stop, the sound becomes lower.
I asked the dealer advisor to send me the report yesterday, and it is actually showing three faulty codes:
P140471 (S - STORED) Exhaust flap 2 has a malfunction. The actuator is blocked.
P140472 (A - CURRENT) Exhaust flap 2 has a malfunction. The actuator does not close.
P002177 (S - STORED) The position of the intake camshaft (cylinder bank 2) deviates from the specified value. The commanded position cannot be reached.
I think the car might be experiencing some airflow issues. I think superswiss is probably right that these codes need to be addressed first. I'm going to a new dealership tomorrow since the previous advisor doesn't seem to be familiar with the car. I'll keep you posted.
Can't say my engine lugs in Comfort mode. In fact the transmission downshifts the moment I let off the throttle and start slowing down, so it's pretty much always in the right gear. It often drops multiple gears, too. Like jumping straight down from 9 to 7, or 5 to 3. It really has adapted well to my around town driving.
EDIT: When I'm in Race mode I also put ESP in Sport Handling, which activates the AMG DYNAMICS Master mode making the handling so much more neutral and controllable for drifting. The locking differential really shines in Master mode, too.
