C63/C63S AMG
Track pace c63s
Old Feb 24, 2024 | 04:41 PM
eytam bh's Avatar
mercedes c63s cabriolet 2020
Track pace c63s
A question please, I don't see a track pace function on the screen in my c63s , does anyone know why? C63s 2020 facelift cabrio
Old Feb 24, 2024 | 05:03 PM
superswiss's Avatar
2019 C63CS
Best guess is that it isn't offered or is an extra cost option in your market and your car doesn't have it. I thought it was standard in the S, but maybe not everywhere.
Old Feb 24, 2024 | 05:16 PM
eytam bh's Avatar
so Okay, do you have a suggestion how I add this system? It should come with the car, right? Is it possible to add?
Old Feb 24, 2024 | 05:26 PM
superswiss's Avatar
2019 C63CS
You can contact MBHouse for example. They offer a retrofit.
https://www.mbhouse.ca/store/track-pace.html
Old Feb 24, 2024 | 05:31 PM
eytam bh's Avatar
But is it possible to add it? Go to a Mercedes garage?
Old Feb 24, 2024 | 05:32 PM
eytam bh's Avatar
Is this an update of the software in the system or is it an addition to the system?
Old Feb 24, 2024 | 05:39 PM
superswiss's Avatar
2019 C63CS
No. Mercedes themselves doesn't do retrofits on existing cars. Track Pace is available as a download on newer models with MBUX from the Mercedes me connect Store, but not on the models such as the C63 that are using COMAND NTG 5.5
It's just software.
Old Feb 24, 2024 | 05:44 PM
eytam bh's Avatar
It's just software.
so I have c63s 2020 , so we’re I can find it & do the software? Thank u for help me
Old Feb 24, 2024 | 05:48 PM
superswiss's Avatar
2019 C63CS
As I said MBHouse and possibly other third-party coder shops. You don't have MBUX, so you can't just download it from somewhere.
Old Feb 24, 2024 | 05:52 PM
eytam bh's Avatar
u mean this ?
Old Feb 24, 2024 | 06:00 PM
superswiss's Avatar
2019 C63CS
u mean this ?
Yes, that's COMAND. I know it's confusing and it looks similar to MBUX, but MBUX is the newer system. I have a 2019 C63S coupe with the same system as you, but mine came standard with Track Pace from the factory. The Mercedes Infotainment system used to be called COMAND and there were many versions over the year. Our cars have the latest version, which internally is referred to as NTG 5.5. It was then renamed to MBUX with NTG 6.0. MBUX is now up to NTG 8.0. It's different generations of the Infotainment system.
If you are confused about MBHouse being in Canada, I see you are located in Israel I believe, then don't be. They do this remotely over the Internet. You will have to purchase or rent an adapter that connects to your car and your laptop, and then they will install/code things remotely from their end. Other shops you can contact are BenzNinja and RJ Automotive. They are all referred to as remote coders. They can install and code additional features in your car remotely over the Internet.
Old Feb 24, 2024 | 06:06 PM
eytam bh's Avatar
The truth is that I don't really understand this and really want to have this Trek package, you know maybe when I get to Mercedes the garage will want to help me? Because I also can't connect to the wireless moment, so I really don't know what to do, thank you very much yes is Israel
Old Feb 24, 2024 | 06:13 PM
superswiss's Avatar
2019 C63CS
You can certainly check with them first. Just out of curiosity, have you looked for it in the right place? It's not on the home screen. It's under Vehicle in the right hand menu.
Old Feb 24, 2024 | 06:16 PM
eytam bh's Avatar
yes I send u pic
Old Feb 24, 2024 | 06:18 PM
eytam bh's Avatar
u see
Old Feb 24, 2024 | 06:21 PM
eytam bh's Avatar
u see
I don't have olso nevigition in the car, could it be related?
Old Feb 24, 2024 | 06:25 PM
eytam bh's Avatar
u see u have this in red I don’t have
Old Feb 24, 2024 | 06:43 PM
superswiss's Avatar
2019 C63CS
Ah I see. Forget everything I said. You have the wrong system altogether. Your car has the entry level Infotainment system. Your system doesn't support Track Pace, online services, navigation etc. You are out of luck unfortunately.
Old Feb 24, 2024 | 06:48 PM
eytam bh's Avatar
Wow, interesting, my car is relatively new at the end of 2020, is it possible to update it or is it impossible?
Old Feb 24, 2024 | 06:50 PM
eytam bh's Avatar
Mercedes told me that the navigation can be opened but the cost is very expensive, almost 1300 dollars
Old Feb 24, 2024 | 06:54 PM
superswiss's Avatar
2019 C63CS
Not w/o replacing hardware, but even then you wouldn't get online services, because your car was built w/o it, so Mercedes couldn't activate the necessary services. You'd be looking at a couple of thousand dollars for somebody to replace your current hardware. This would be a custom job.
There's an SD card based entry level navigation available for your system if the car has the right preparation option. I think whoever you talked to gave you the wrong information. They must have also thought you had the higher level system.
Old Feb 24, 2024 | 06:57 PM
eytam bh's Avatar
I send the guy from Mercedes this pic & he say to me it cost 1300 dollars to open
Old Feb 24, 2024 | 07:01 PM
superswiss's Avatar
2019 C63CS
Yeah, that's the SD card navigation, but that doesn't cost $1300.
eytam bh's Avatar
Ok, so you think there is a way to solve this problem and activated all services and get the track pace ?
Old Feb 24, 2024 | 07:03 PM
superswiss's Avatar
2019 C63CS
Well, nothing is impossible with the right amount of money and finding somebody who can do it, but the short answer is no.
You have already rated this thread Rating: Thread Rating: 1 votes, 2.00 average.
