C63/C63S AMG
Widest Tire Width FL 63S Sedan
Old Apr 6, 2024 | 06:21 PM
seabiscuit's Avatar
2020 C63S Sedan
Ciao Gents-
Did a bunch of searching before posting this, and there was a lot of feedback with Coupe tire width, but haven't seen much info RE Sedans.
Anyhow- I would love to replace the stock 265s on the rear. It looks as though the max is 285 for the rear? Played around with TireRack's custom tire search etc.
Question being- is 285 the widest for a 2020 63S Sedan? If so- Should I run 30 or 35s? I'm assuming ride quality with 35 would be "less harsh", but is there any positive to a 30?
Cheers
Old Apr 6, 2024 | 10:25 PM
GooseHK's Avatar
C63s Coupe (FL)
tl;dr consensus for the sedan is 285 width no issue on stock rims
lots of ifs/buts and further information needed for definitive answers, and ultimately comes down to your own preferences on looks/appearance.
Are you on stock rims, if so, which? It matters for the sake of appearance/look. A narrower rim with a 285 width tire, whilst fits fine, will give you some squareness or possibly, slight 'bulge'.
if you're lowered (springs/coil overs etc) 2xx/30 'looks' fine .... if you're stock height, then 35 probably works out best....... 30's on stock height/rims will leave you with quite the wheel arch gap.
Ride "harshness" is negligible/undetectable by most between the 2 profiles, especially if the roads you typically drive on are poor or dont have good control over air pressures.
there's MANY posts/threads on suitable wheel/tire sizing for sedan's and coupe w205's across the forum with pictures......
Old Apr 7, 2024 | 10:23 AM
seabiscuit's Avatar
2020 C63S Sedan
This really helps Goose, thank you Sir! Here are the rims I have:
Old Apr 8, 2024 | 07:30 AM
dctwc63s's Avatar
2019 C63S Sedan
Though 285 will fit on stock wheels, I wouldn't do it. Too wide for a 9.5" wheel imo. Read in another thread that someone installed 285 or 295 (can't remember) on stock wheels and he mentioned the rear of the car felt floaty under heavy braking.
I'd go front 255/35 rear 275/35 on stock wheels.
Old Apr 8, 2024 | 05:48 PM
mokawop's Avatar
c450
I have tried both 295/30/19 and 285/35/19. On the 295 grip is very good and you won't spin at all. However during hard cornering you have less feedback from the rear and during hard acceleration it does this thing where it feels like it does a little jiggle in the rear. I actually have a video where you can see it do the little jiggle lol. I however have not personally experienced the braking floating feel. The 285 I went with a 35 sidewall and I am very happy with the current setup. More than enough grip, good cornering feel, and for me it filled the tire gap.
Old Apr 8, 2024 | 06:07 PM
LR63s's Avatar
C63s W205
I run 255/35/19 , 285/35/19 & I’m happy with the set up going on 2 years.
Old Apr 8, 2024 | 07:07 PM
seabiscuit's Avatar
2020 C63S Sedan
Thanks fellas- 285/35 it is!
Old Apr 8, 2024 | 08:19 PM
36EGMA's Avatar
C63s
Literally just went with 255/35 and 285/30 on the stock 19’s and I am running spacers on my sedan.
