C63/C63S AMG
Tire Options on Stock 19/20" Wheels
Old Jan 23, 2019 | 01:44 PM
mrguitar's Avatar
c63s
Question Tire Options on Stock 19/20" Wheels
I'm sure this has been discussed ad nauseam but just wanted to get an idea of the largest tires I could put on a '19 Cabriolet without *any* modifications at all (i.e. no wheel changes, lowering, spacers, etc.). This would be fore the 19/20 cross-spoke black wheels on the W205. Not going for any particular look (definitely don't want wheels/tires to look bad or ugly though); just looking for a little more grip. Which tires/sizes have you guys had good experiences with? FYI, this is for SoCal, so only care about summer tires.
Thanks,
Ed
Attached Thumbnails Tire Options on Stock 19/20" Wheels-12-14-2018_my19-c-cab-dog.bmp
Old Jan 23, 2019 | 02:11 PM
See63esS's Avatar
2019 Audi SQ5, 2011 Toyota Tacoma TRD 4wd, 2016 Ford Focus se Hatchback
Coupe or Sedan?
Old Jan 23, 2019 | 02:13 PM
mrguitar's Avatar
c63s
Originally Posted by See63esS
Coupe or Sedan?
Sorry, Cabriolet. OP updated.
Old Jan 24, 2019 | 10:37 AM
See63esS's Avatar
I just put on Michelin Pilot 4s 265 and 295 on my coupe. Huge improvement.
Old Jan 24, 2019 | 10:58 AM
C63SVERT's Avatar
2018 AMG GTC Roadster. 2013 SL65 2018 GLC63
i have the same setup on my 17' C63S cab. amazing tires, huge improvement all around.
Old Jan 24, 2019 | 10:59 AM
mrguitar's Avatar
c63s
Thanks! You did nothing other than change to the wider tires? No other wheel/tire-based mods, right? Thanks again.
Old Jan 24, 2019 | 11:00 AM
mrguitar's Avatar
c63s
Makes you wonder why MBZ doesn't just use the wider size straight from the factory?
Old Jan 24, 2019 | 12:10 PM
tiledhouse's Avatar
W205
some members on the site have gone up to 305 rears
Old Jan 24, 2019 | 12:50 PM
See63esS's Avatar
Nothing
Old Jan 24, 2019 | 04:22 PM
mrguitar's Avatar
c63s
No rubbing or weird look? What's the downside of going that big in the rear?
Old Jan 25, 2019 | 12:56 AM
CrashTX's Avatar
2019 C63S Coupe - Graphite Grey Magno
Thanks,
Ed
yup. lots of other threads on the topic. By all accounts, Michelin PS4s are the best option to replace the stock PSSs. If you get a tune, gotta go bigger in the rear if you want to have any hope of traction. The part that's not entirely clear to this noob is that most of the posts also increase the front widths by the same as the rear. I'm not sure I understand this, so would appreciate an explanation. Is that just esthetics so the car doesn't start to look like a dragster with a disproportionately smaller tire in front? I can see that (pun). Or is there a performance consideration? Lots of posts say 305s fit really nicely in the coupe without any mods to the car. But, going to a 275 up front to match the 20mm increase in the rear sure seems like a big (and hard steering) tire. In other threads I've read 265 fronts/305 rears and it seems like a good setup with no mods necessary. Anyone try a 275/305 combo?
You're going to be giving up a some handling for added traction with the wider tires, but going up just 10 mm is probably not going to be that noticeable on the road (unless you routinely take lots of aggressive twisties.) Now 20mm in back (305s)? Gotta think you're noticing that difference. I think you'll probably notice the increase in the fronts more than the rears, because that feedback will be in the steering. The 295/265 setup seems like a good balance.
Old Jan 25, 2019 | 11:13 AM
mrguitar's Avatar
c63s
My understanding is that, usually, the front tires are widened for quicker and better grip on turn-in...others who track more often can comment, but I'm sure this applies on the street as well. I too want to go as wide as possible in F/R without any modifications, and without making the ride more uncomfortable or loud. Sounds like P4S is much better than PSS...? If 305s work in the back, I'm game for 305s! LOL
Old Jan 25, 2019 | 05:25 PM
See63esS's Avatar
I don't like the look of 305s on stock wheels. Tire starts to overwhelm the wheel.
Old Jan 25, 2019 | 05:31 PM
mrguitar's Avatar
c63s
any pics?
Old Jan 25, 2019 | 06:43 PM
See63esS's Avatar
any pics?
I don't have any but there are some on here if you search.
Old Jan 26, 2019 | 04:51 AM
Freywaldau's Avatar
2017 C63S AMG coupe
Is it on 19" rims? My current rims are 19 front, 19 back. Since Michelin Pilot Sport 4s is not available in 285/30 R19, I'm thinking to go for 295/30 R19 for which PS4 is available. I'm not sure if I need to also increase the width of front tires, from 255/35 R19 to 265/35 R19.
Old Jan 27, 2019 | 02:21 AM
See63esS's Avatar
no. 19/20 cross spoke
Old Jan 27, 2019 | 05:45 AM
untamedd's Avatar
2019 AMG GT R
what is the recommended tire width for the front if you're running 305s in the back?
Old Jan 27, 2019 | 11:07 AM
Freywaldau's Avatar
2017 C63S AMG coupe
Porsche has this combo for 911 Carrera: front 235, rear 305 on 19" rims.
Old Jan 27, 2019 | 12:49 PM
untamedd's Avatar
2019 AMG GT R
was that a typo or did you mean 235? because stock with the 19/20 rims the fronts are 265 so id imagine id have to go with something bigger if im going from 285 to 305 in the back
Old Jan 29, 2019 | 09:03 AM
Freywaldau's Avatar
2017 C63S AMG coupe
Sorry, it's 245/305. See this:
https://tiresize.com/tires/Porsche/911/2018/
Old Jan 29, 2019 | 09:16 AM
Freywaldau's Avatar
2017 C63S AMG coupe
Actually for Porsche 911 version 997 (year 2015) it is 235/305. See this:
https://rennlist.com/how-tos/a/porsc...reviews-387303
Old Aug 8, 2023 | 06:14 PM
mrrobinson53181's Avatar
C63S AMG
here is a pic with 305’s on the rear.
305 rear
Old Aug 11, 2023 | 04:50 PM
red60R's Avatar
2017 C63S
I hear the 305's hook up much better if you'd had tune work done than the stock tires
Old Aug 11, 2023 | 05:27 PM
C63S AMG
Yes but still get crazy wheel spin….tuned, catless dp’s, filters and BOV’s
