C63/C63S AMG
Measuring Body Gap Dimensions - How is reflected?
Old Sep 10, 2024 | 07:08 PM
yukonsc's Avatar
Seeking
All,
I picked one of the most popular forums to post this one - I am looking at a workshop pages for measure the gap dimensions on hoods, doors and lids and have the the Measuring tool as well. Does anyone know what the measurements mean when there is a 3, 6 or 3, 9 - what does the 6 and 9 mean? I believe the 3 is the mm gap but how does the 6 or 9 play into it? Then how does the (+/- 0,5) play into it as well? Again all dimensions are referenced like this I am using this on as an example because I found it on here and it was easy to take a snip it.
Old Sep 11, 2024 | 05:40 AM
ygmn's Avatar
2015 E400 Sedan
so for front door edge to front fender the gap should be 3.6mm +/- 0.5mm
or in other words 3.1mm to 4.1mm is the gap between panels.
You can measure with calipers or if you have them GO - NO GO gage
these are flat bars machined to precise thickness.
The GO is machined to the Min gap dimension and has some tight tolerance it is never less then the min gap.
The NO-GO would be machined to be just a hair bigger then the MAx gap.
Some MB engineer decides.
The GO must fit in the gap and the NO-GO must not fit.
There are other methods.
Old Sep 11, 2024 | 09:48 AM
yukonsc's Avatar
Seeking
Thank you. What you wrote is what I assumed. 2 things caused me to write the question - The use of a comma instead of a decimal point and the mercedes referenced Mercedes tool - feeler gauge p/n 129 589 03 21 00 has whole measurements (as you would expect) 3mm 3.5mm 4mm not 3.6 and 3.9. Just doesn't make sense to me to have 3.6 as the base measurement.. with a +/- .5.
Again - I get it its car body panel not a precision tool. I'm not breaking out the calipers to get 3.5 vs 3. I'll use the 3.5mm stick and if I can't get 4mm gauge in we are good.
Again thank you.
Old Sep 12, 2024 | 12:28 PM
Spaceguy65's Avatar
2021 C63S Coupe
Most European countries use the comma for decimals rather than the period
M
