C63/C63S AMG
Transmission issue
Old Oct 22, 2024 | 06:29 PM
gforc3's Avatar
C63 Coupe
Transmission issue
Hello all,
I've looked through a bunch of posts and havent found a clear answer to this so I'm gonna give it a shot here
My car is a 2017 sitting at about 32k on the clock. At about 28k (probably 2-2.5 years ago) I did all major services including the transmission service at a reputable performance shop near me. The car has been great until the other day. As I was coming back from a drive (nothing stands out from that drive vs any other time) I was pulling away from a stop sign in comfort mode and the 2-3 shift seemed to slip and then bang into 3rd. Thought that was strange and switched modes.. its doing it in all modes including manual. Plugged in my scanner, no codes. Removed the tune and tried again same problem. Tried the tcu reset procedure, that didnt work. Disconnected the battery overnight, same thing. The transmission acts normally in every other gear its just the 2-3 upshift.
Praying its just low on transmission fluid. I have no leaks on my garage floor but who knows.
If anyone has experienced anything similar and knows what the issue is please let me know. I already purchased another transmission service kit from fcpeuro https://www.fcpeuro.com/products/mer...tosin-7229late
Thank you
edit- no tcu tune, just ecu
Old Oct 23, 2024 | 10:14 AM
Roysup's Avatar
2018 C63S AMG Coupe, 2019 Jaguar F-Pace SVR
I have experienced this on other vehicles and it was in fact low transmission fluid. I'd check that first.
Old Oct 23, 2024 | 08:38 PM
Jimmy_c63s's Avatar
Originally Posted by gforc3
Hello all,
Thank you
Fluid low time for a service
Old Oct 23, 2024 | 08:58 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
I have a rule on any car. If the fluid you taking out has a interval of every +50k kilometers, I let the dealer do it or do it myself. I would not trust anyone else aside the people who knows the correct procedure or myself who is trying to be a master mechanic. I would bring it to the dealer and let them redo the tranny sevice.
Old Oct 24, 2024 | 12:52 AM
gforc3's Avatar
C63 Coupe
Thank you for the replies. Someone else told me a dying battery could cause this also.. I have not replaced the battery since I bought the car so I’ll do that as well. When I plugged in my diagnostic tool I remember seeing the voltage at 12.3 which I didn’t think was low at the time but apparently it is.
I’ll be sure to update this thread after both the transmission service and battery replacement is done
Old Oct 24, 2024 | 01:26 AM
doggo's Avatar
Keen to hear your results as I feel mine from 3-2 sounds similar to yours but not as harsh
Old Oct 24, 2024 | 07:00 AM
gforc3's Avatar
C63 Coupe
mines fine downshifting 3-2 only the up shift 2-3
Old Oct 25, 2024 | 03:58 AM
doggo's Avatar
Yeh wonder if it can be the same solution thought
Old Oct 25, 2024 | 10:38 AM
jimyj's Avatar
E320
Based on my experience with these transmissions, when you're getting a harsh 2-3 shift with no other symptoms, it's often related to the B2 brake band servo or the pressure control solenoid that manages the 2-3 shift. The metallic particles from normal wear can accumulate in the valve body channels, particularly around the 2-3 shift solenoid, causing erratic pressure control. I've also seen cases where the transmission conductor plate (the internal wiring harness) develops micro-cracks that only manifest during specific shift points, and the 2-3 shift is particularly vulnerable to this due to the load conditions during that transition. You'll want to do a complete scan of all modules, especially the TCM, with a proper scanner. I've been using my youcanic scanner lately because it gives me access to the live data streams during shifts, showing actual clutch application timing and pressure values - crucial for diagnosing Mercedes transmission issues. A basic scanner like the Launch Creader VII+ won't show you the adaptive shift parameters or solenoid response times that are essential for proper diagnosis. Sometimes these transmission issues store fault codes in the ESP module too, since the wheel speed sensors and transmission control are interconnected. Have you checked the transmission fluid level while the transmission is at operating temperature (80°C) with the engine running?
Old Oct 25, 2024 | 11:16 AM
gforc3's Avatar
C63 Coupe
thank you for the reply much appreciated. I have not been able to check it yet, this week I will be able to at a friends shop. If it is the brake band servo or solenoid does that typically mean replacement of those parts? Or will cleaning and flush/refill solve it?
Old Oct 30, 2024 | 01:06 AM
gforc3's Avatar
C63 Coupe
Quick update to this problem, looking like I’ll need a conductor plate repair/replacement
Old Oct 30, 2024 | 05:24 AM
W205C43PFL's Avatar
Thanks for the update, good to hear you figured it out.
Old Oct 30, 2024 | 06:21 AM
gforc3's Avatar
C63 Coupe
No problem. I know the car is getting kind of old and that transmission is basically ancient tech at this point but this car as far as I've owned it has been cared for to the best of my ability. Service whenever required, not neglected in any way. Driven hard at times but thats what these cars are for. I'm just kind of shaking my head in disbelief that this is what the problem is. Based on some searching around this is an extremely common problem on all 722.x transmissions and the best part is the conductor plate is linked to your key so you cant just purchase a new one.
Hopefully this is the extent of the problem, I will update as this goes on
Also quick note just to help anyone in the future, I had not driven the car between the time it happened and the time I drove it to the shop. Driving to the shop the problem was way worse, in more gears, and also would not rev match downshifts at all in any mode (which it was ok with when it initially started happening). Stepping on the gas at highway speeds causing a downshift was violent
Old Oct 30, 2024 | 07:42 AM
W205C43PFL's Avatar
Ya I understand where you are coming from and indeed sorry to hear that.
Old Oct 31, 2024 | 07:57 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Have you ever heard of this company??? They claim you don't need to code it, $325 for the repair seems great, if it works as advertised. https://circuitboardmedics.com/merce...BQbftBJW-axT3Z
Old Oct 31, 2024 | 08:04 PM
gforc3's Avatar
C63 Coupe
I have, actually have it open on another tab right now lol. The shop is looking into options that may be the way we go. There may be other issues involved
Old Dec 6, 2024 | 06:55 AM
gforc3's Avatar
C63 Coupe
Update.. shop installed the new valve body/conductor plate and has not fixed the problem. They’re saying there’s a bigger problem with the transmission but haven’t gone into detail. They’re recommending replacing the transmission entirely with a used transmission with about 20k on it. I’m pretty conflicted about what to do. I would much rather replace whatever is broken on my transmission than swap to one that has probably been in a severe accident.
any insight would be greatly appreciated
thanks
Old Dec 6, 2024 | 08:41 AM
W205C43PFL's Avatar
thanks
Um they usually install remans, why would they install a used one directly from another vehicle?
Old Dec 6, 2024 | 08:45 AM
gforc3's Avatar
C63 Coupe
it may be rebuilt I’ll have to check with them today
Old Dec 6, 2024 | 08:55 AM
W205C43PFL's Avatar
I see.
