C63/C63S AMG
Battery swap question
Old Feb 11, 2026 | 11:04 AM
Dr.Ron's Avatar
C7 Z06
Hello. I have to replace my battery. I trickle charged it overnight but it still is testing low. I noticed what appears to be a castle nut or something similar ont ehfront,left,towards the top of the battery that has a cable connected to the side of the trunk. I'm guessing it is a ground? Anyway, what type/size of nut is that if anyone knows?
Thanks!
Ron
Old Feb 11, 2026 | 03:17 PM
Dr.Ron's Avatar
C7 Z06
Never mind, didn't need to remove it.
Old Feb 11, 2026 | 04:05 PM
C63s_Jack's Avatar
AMG C63s Coupe
Do not forget to register the new battery by tester
( Xentry).
OEM battery is in my mind from VARTA (AGM).
Old Feb 11, 2026 | 04:47 PM
Dr.Ron's Avatar
C7 Z06
( Xentry).
What do.yku mean by register it?
Old Feb 12, 2026 | 01:07 AM
C63s_Jack's Avatar
AMG C63s Coupe
Inform the vehicle's electrical system that a new battery has been installed.
Adjust the battery's performance specifications if necessary.
I was told that this was what needed to be done.
You need a tester with this funktion.
Old Feb 12, 2026 | 06:20 AM
japamg's Avatar
Final Edition C63s / RS3 Sportback
No need to do that, changed it many times no issues
Old Feb 12, 2026 | 08:18 AM
C63s_Jack's Avatar
AMG C63s Coupe
The MB bulletin say‘s tell the elec-system that a new fresh battery is installed & correct the spec of the battery (AH etc) if something has changed.
I think without this to do the car will drive too.
But first AMG Service rule - work like MB/AMG says !
Old Feb 12, 2026 | 08:24 AM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Depending on year of vehicle, the battery management system supposedly appreciates being informed of a new battery, so the system can modify its charging policy, or something like that. Not sure if there is any data beyond anecdotal if this improves the life of the new battery in any way, but it may find favor with the mercedes gods. A simple scanning tool can input the new battery information.
