Bose Sound System - 2001 CL600
2001 Lorinser Edition CL600 (SOLD)
Does anyone know the specs on the sound system in an 01 CL600 (watts, etc.)??? I can't find the specs anywhere.
NSX
Bose doesn't print specs. And its for a reason. The glorified clock radio sound sort of speaks for itself. The CL Bose system is pathetic.
Actually, I think the sound system is pretty damn nice. I just wanted to compare with other systems. I guess I'd need to know the real watts.
Couple of things though - the rear window shade rattles just a bit when it's in the lowered position and the radio's cranked. If you put the shade up, no problems. Another thing is that this car pretty much demands that you drive it with the windows down in nice weather, so the stereo could use a little more umph to sound rich, full, and tight at slightly higher volumes - but again, I think it's pretty darn good for what it is.
-V
NSX
Wow I guess its all relative because I hear all sorts of flaws. From a total lack of deep bass to a nasal midrange. I think I am used to my lexus system that blows this thing away and that car cost less than half this car new... ten years ago. It still sounds better.
I guess if you compare it to some other cars its OK, I just expect better in a $137,000 car.
Poll on Audio Settings...
Bass +5
Treble +8
Balance 0
Fader 0
Other settings
I keep it on Driver optimized, and switch to Medium or Large ambient soundstage depending on what I'm listening to.
-V
Treble +8
Balance 0
Fader 0
Other settings
-V
It'll be hard to find exact specs on Bose products. They are famed to not put any specs for the same reason AMG2GO said; they are just glorified clock radios. I'll try to find out if there's a way to figure out specs by hand though.
NSX
Originally Posted by Vendetta
Bass +5
Treble +8
Balance 0
Fader 0
Other settings
-V
Treble +8
Balance 0
Fader 0
Other settings
-V
Using the bass and treble settings we could not get it to be even close to right but I can tell you your levels are too high on both bass and treble. You will wind up with some peaks. The best response was actually measured with treble +2 (to plus 3), Bass +3 (to plus 4), and medium ambient. 8 and 5 are too high for a good source.
OK its funny you brought this up because we ran an analyzer in this car (from our home systems, software from SMAART PRO by JBL) with an expensive lab mic and took some measurements with the car on and off. Its FAR from perfect, there is almost no bass below 40Hz, and treble drops off around 15K and there are plenty of peaks where they should not be.
I'm curious about your mic placement though - where did you sample the sound? Driver side, passenger, center? It's hard to argue that the soundfield dosen't feel more accurate when you select driver optimized timing.
Also, did you take any measurements at speed? That would be a more appropriate sample. 'Cause while I like the stereo in the car and all, I wouldn't say it's good enough to get me to just sit in it to hear my favourite CDs.
[Edit] As I was adjusting the settings just now I noticed that when I open the driver door while the unit is playing, sound cuts off to the driver door speakers. Is this faulty wiring or some incredibly compassionate engineering by MB to not blast those around you when you open the door? Do yours do this also? The sound on mine cuts out as the door swings between the first and second hinge rest points.
-V
NSX
I couldn't measure at speed. Our gear runs 110V AC. We measured at various points and took an average. Drivers, passengers, and center. I don't think my speakers cut out... I think you may have a problem! I have seen it before it was a bad harness.
NSX
BTW the car needs a subwoofer. If that was there, we would probably LOWER the bass control and get the flattest response. With +3 or +4 the bass improves in the lower region a bit but then you get a nasty 100Hz peak. I plan on adding a sub. I just can't deal with what is there now. As much I like keeping the car stock, I may have to do this one mod.
Yeah, I know what you're saying. I'd hate like hell to start messing with a debatably good-enough thing. Where would you put the sub, and it's amp?
NSX
I have to look again but there is some sort of opening dead center in the rear shelf I have seen subs put in there before... I have to do some research on this. It will have to be done with MINIMAL intrusion into the car. And hopefully no factory wires cut. I will check into it soon once I can "borrow" my car from MB's service center again!
Anyway, back on point... I read this thread (https://mbworld.org/forums/audio-electronics/19734-bose-system-i-m-not-impressed.html) front to back and decided I'll leave to the real experts. I've wired up sound and lighting systems before, but we're talking proprietary stuff here that I'd rather be able to hold someone else accountable for should things go wrong. My prereqs are that it look stock and sound twice as good - otherwise it's not worth the hassle.
Here on Long Island, there's a place in Syosset called Soundcraft that does the best installs I've ever seen. Not cheap, but damn... real tight. I've had many a vehicle outfitted there. If I get there about this, I'll post up what I find out.
All the best,
-V
I thought about modding the sound system but so few people have worked on these cars that I just never trusted anyone to do the job without mucking up something.
So hello from the service department at MB Huntington. Free online service, not bad. Wish I didn't need to be here though...
So that problem with the driver door speakers cutting out (see a few posts back) turned into a bigger deal. Now the rear speakers and driver door speaker cut out all together. So they took the door apart last week and no joy - it wasn't in the door. Sent me on my way without fixing it because it was going to require more time. Problem is that when they put the door back together, they screwed something else up, the autoclose mechanism that pulls the door tight on the driver door stopped working. Now I'm back and hoping to leave with all my arms and legs after paying for the service.
I'll post the results when all's said and done.
Ciao,
-V
Ciao,
-V
you've gotta love service today. Brought my car in for various work to be performed. Came back with an extra 40 miles on the od, scratches and a nice divit on the hood of the car (over the wheel well)-probably from some tools being dropped. Didn't notice the dent till I drove off the lot, 10 min. later. Fun, fun, fun.
BTW sorry for getting off topic.
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
...I'll post the results when all's said and done.
Ciao,
-V
Ciao,
-V
Oh, by the way - I recall a thread on here where someone's driver door pneumatics were failing? Well that was one of the wires that had broken during the first diagnosis and caused my door to stop pulling tight. Perhaps that was *his* first wire to go.
-V
Liz, tell me that you took your car back and raised hell.
oh yeah! Funny thing is the sa acted as though he was doing me a favor by fixing it and said that he would not spend another penny on my car. I told him I didn't want to be there any more than he wanted me there and that I would appreciate him checking every scratch on the car to ensure that it comes back the way it went in. In the end, the car was fixed perfectly and things were left on a positive note, with the exclusion of the upside down spilled apple juice cup on the rear seat (thrown by detailers from it's original locale)which i didn't bother to mention-too frustrating. BTW, drove off the lot and noticed that the center a/c vents stopped working. Overall, I must say the sa does try to help, it must be a very frustrating job- I am only one person. I can only imagine how often this happens. I would not want to be in his position.
All of them, as much as I can...
Liz, I suggest you do what I did...know the card that they give you with the invoice? The one that asks you to rate the service. I filled it out front and back detailing my displeasure with regards to delivery prep on a new car I bought. And then another about sloppy work and cleanliness on my AMG. I got a letter from the HQ office in Montvale, NJ. Then next time I went to the dealer service dept, I was apprehensive (thinking the proverbial waiter-spits-on-your-food) but pleasantly surprised. I was treated like God, given a loaner and instant service without prior appointment, and a personal "Everything OK? " from the Service Mgr. when I picked up the car. More importantly, the service (wheel balancing and alignment) was done properly, the car was washed and was really clean.
Sometimes, a good bashing works for these guys...
![wwf](https://mbworld.org/forums/images/smilies/chairshot.gif)
