Damn ABC light keeps coming on....
Well, looks like it is time to make my bi-monthly dealer trip. The ABC light keeps coming on.....not the red warning one..but the blue VISIT WORKSHOP one. This problem has been present since the car was bought in Janu. 04.
Well, actually, it started last June. Then it would do it almost every other time the car was driven...the light would come on...and if I kept driving, one side of the car would become lower than the other. I had to turn off car and restart it to re-balance it.
I thought I had it fixed in November 2004 when apparently a blocking valve had shorted, causing this. I got it fixed...yet for about a week after, the light kept coming on, albeit not as much. It started to get colder here and it did not come on once the whole winter. It now is starting to get warm in the last 2 weeks and it has started coming back, the last few days it is constant. Any ideas?
All of them, as much as I can...
Good luck troubleshooting that. A related question...my CL squats on 1 side after sitting for a week or more. The red warning goes on saying ABC too low!. I start it and press the ride height button and she jumps right up. Is this normal?
Mine ended up being a strut. There was a service bulletin out on this I guess that they would not have been able to identify if not for my rather specific description. My car would not do this during the colder months...only during the warm ones. My advisor said it made perfect sense from reading the bulletin why it would only do it in the warm months.
If I don't use my '02 for three weeks or so, the front drops and the ABC warning light comes on when started. Once I put it in gear, it comes right up to normal height. I don't know if this is normal or not.
Well...., according to 1 service advisor, it's normal. 2 Techies from mercedesforum.com said it is probably a leaking valve to the offending corner that needs to be replaced. I also ran into the Service Mgr of rallye motors and he said the same thing. Valve. Not an amergency situation but needs to be checked into service.
The tech suggested changing the oil (Pentosin CHF 11S) and filter and giving the system a workout; as that sometimes solves the problem. I tried it and my car is parked away at my other house so I'll se next weekend if it did work.
I bought expen$ive extended warranty that covers it so I'm checking it in in a couple of weeks.
Checked my car in this morning for a routine service. While it's there, they're gonna look into why the car leans just a little to one side. I never get any warning lights or anything like that, and the lean is barely noticeable until you take a tape measure to the car. They're gonna do a complete diag on the system, we'll see what comes of it. I noticed that there was a recall for the ABC system on the 2001 CL (MB #2004070012), but my SA says my car is not affected. I have a warranty, so I'm actually hoping they find a problem to fix.
-V
-V
-V
-V
Originally Posted by techbike
V, This is what my car is in at Rallye for. (the recall) and also my RF droop poblem, which could be related. It doesn't happen when I use the car, but when I leave it out east for a week, the RF is down.
-V
...mine does that alot on the driver's rear wheel, no "abc" lights have come on yet, though. as soon as i start up and move fwd or back , she rises back to normal. going in for service soon, so who knows
CL's back...
...and apparently, the recall for the ABC hydraulic line applied to my car. They claim it's fixed it. No charge. Actually a good excuse to get them to change the Pentosin oil and filter for the ABC as it was part of the covered procedure. I was going to do it myself and found the filter's $60 and 4 cans of the Pentosin at $28 each!
I'm putting the CL back to sleep for a couple of weeks again so we'll see if it worked.
I'm just wondering all this because maybe they were able to shoehorn your car into the recall even if was not one of the relatively few truly affected. A very cool thing for the dealer to have done if that's the case. If so, I'm changing dealerships.
-V
Just an update on the ABC situation... I pulled my car out of the service department before they actually fixed it. Reason being I just purchased the warranty last week and didn't want to raise any flags or make the guy that sold it to me look bad by having such a major repair so soon.
I'll wait a few weeks and then take it back. It's not critical at this point.
-V
-V
You're a lucky guy, bro. That's about $2,000 to fix if you weren't covered. They came right out and told you that your car was affected? I wonder why they didn't notice it earlier. At the dealerships, when they log in your VIN, it tells them up front if your car has any "open" recall campaigns and they fix it outright to avoid liability should, God forbid, something go really wrong. (This particular recall was in place to avoid engine compartment fires due leaking suspension fluids.) When was the last time your car was at a dealership?
-V
-V
