CL-Class (W215) 2000-2006: CL 500, CL 600
changed a dead battery and now abs, esp, and bas lights are on
Old Jul 30, 2006 | 09:21 AM
V12toHybrid's Avatar
Kia Sedona
my battery died last week and i finally changed it with a after market one last night and then when i cranked it up, the computer is showing esp and bas malfunction and the abs light came on. tried that ecu resetting procedure (key to sec position, press gas padal, turn off, release gas, remove key) but it didn't work. the car was fine before the battery failure. is the new battery messing up the computer or there are something truely wrong with the car? going to drive it this am and see. will report back.
Old Jul 30, 2006 | 11:19 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
For an '02 CL500, the procedure to restore the system after battery disconnect is to start the engine and turn the steering wheel fully left and then fully right. That should solve the warning light problem. The other procedures involves windows which requires closing all windows and holding each button in the up position for a second or so. Lastly, open the moon roof to the rear open position and again hold the button down for a second or so. I don't know if this procedure is for your vehicle. Check your manual if this doesn't work. Good luck.
Old Jul 30, 2006 | 11:27 AM
Kia Sedona
DUDE!!! THANK YOU SOOOOOOOOO MUCH!!!!
you just made my day!! going to try it now
Old Jul 30, 2006 | 01:51 PM
Kia Sedona
problems solved just like you said, turn steering wheel to the left then to the right and all the lights are off. it's actually in the manuel just like you said as well. resetted the time, windows and sunroof also. can't thank you enough. i love mbworld
Old Jul 30, 2006 | 08:47 PM
bltserv's Avatar
2005 SL55, 2000 CL500
Talking Battery Reset
I freaked when the MB Field guy replaced my battery
and all those warning lights came on.
He was cool and said not to worry.
He did exactly what was discribed in the thread.
Steering wheel, Windows, I think he hit the ESP and ABC buttons too.
After that all was fine.
Old Jul 30, 2006 | 11:59 PM
Jud Chapin's Avatar
Glad I could help. I don't know why MB doesn't explain this to customers when they buy a CL or other MB. I specifically asked the service writer about this when the car was first in for service. He talked about how to redo the radio favorite channels and how that was all that needed to be done. I didn't believe him at the time and found out later, like you, when all the warning lights came on.
Old Aug 1, 2006 | 09:42 AM
Whodat's Avatar
2000 CLK 430 Cabriolet
They want you to bring it back to them so they can charge you 2 hours labor for a stupid computer reset!
Old Jan 18, 2014 | 03:16 PM
BigJohn06's Avatar
CL500
Thanks. You're a genius.
Thanks Again
