Any problem-free CL's out there?
Anyway
today I just completed its 286000 mile
never had a transmission issue or fluid change throughout its 19 yr life and it came with history as long as my arm! Every single receipt and repair
In 19 years
Replaced two abc high pressure lines with higher rated ones that I had made at the local hydraulics hose place..$35 each
its on its second ABC pump and I replaced all the o rings in the ABC valves ....less than 3 bucks but 2 hours of work
one ride sensor required replacing
two suspension struts have been replaced
wires in door repaired
washer bottle sensor replaced
one seat squab
every ball joint and bushing on suspension has been replaced some two or three times .
wheel bearings still good
still has original exhaust system
They where built pretty well I think and running on propane really economical to run with propane half the price ...tank in wheel well..
retired so car does very low miles, it had 70k when purchased, just love the styling of the car, let heart rule brain but hey it is my money!
I looked at many other vehicles from Maserati, Bentley GT and BMW 750IL and the CL600 was the best look IMO, but thanks to this website I went in eyes wide open on the problems I was going to accept.
So far...
Changed oil, trans fluid, brake pads when I purchased car at 72K for preventative measure $600
ABC pulsation dampner noisy $500
Windshield Washer pump fail $120
Rear window control $450
Coolant leak from turbo o-rings $650
Radiator cracked $900
current mileage $87K
still love the car
