sleep among the clouds
is he cuckoo?
Try and run it buy your mechanics... i don't think anyone on the forum is doing this when parking...
I'm gonna try to raise the car when parked for extended periods of time and see what happens. I was begining to think the suspension was getting ready to go out
The DTB then goes on with condition 2 as follows: "If a vehicle lowers only after being stationary (eng. off) for more than approx. a week, this is a characteristic of the hydraulic design and is not a complaint that requires a repair. The check valves in the front and rear axle valve blocks have a metal seat. The inherent design of this sealing method, required for system durability, permits a limited level of leakage which can result in the vehicle slowly lowering. If the vehicle does not lower significantly until after approx one week has passed, do not perform any repair attempts."
If I sit in the car, in park, with the engine running the car will drop really low. It does it all the time, everytime, after about ten minutes. I get no warning sounds or lights. I never have the car raised upusing the ABC...it stays in the standard mode. Is this normal? It sits in the garage quite a bit but I have never noticed a drop.
ALi
try it out, might do the same to others.
ALi
1 Raise vehicle chassis
2 Lower Vehicle chassis
3 indicator lamp
4 indicator lamp
It also states the following: "The vehicle chassis ride height is raised or lowered automatically according to the selected setting and to vehicle speed. This helps to increase vehicle handling safety and lowers fuel consumption. The selected setting is stored in memory, even with the electronic key removed from the starter switch". It explains more about it on the next page. It starts on page 283 in my operator's manual.
This may be what you guys are experiencing. Like I said, I've never touched mine but I think I will now. I've never taken the time to read my manuals but probably should. Keep me posted.
3 indicator lamp
4 indicator lamp
thanks Jud, i think we already KNOW what it DOES, its what its doing thats NOT stated that I'm wondering about.
ALi
3 indicator lamp
4 indicator lamp
what we are TRYING to explain, is that if you sit in your car with the lower option selected(no lights), the car rises and falls over approx 10min intervals. so if your sitting in your driveway, with the car running, your car will rise to the Highest point, and once reached, it will drop to the lowest and start the process over again. the rise is Barely noticeable, but the Drop is VERY noticeable.
try it out Jud, wont hurt nothin more then Gas and time lol.
ALi
In all seriousness, though, I sort of find it hard to imagine that MB would build a car that w/o warning would drop very suddenly and severely at idle considering that there are some fairly old people that drive the CL's. I would think it would scare the you know what out of them. Again, just my 2 cents. I will give it a try, though.
DO NOT DRIVE or DRIVE SLOWLY. This is a problem, not an intended function, I am sure. As soon as the running engine creates enough pressure in the ABC system, it raises the suspension to the selected setting (of the three available) If it does not raise the car, you have a serious - and very expensive - problem.
Will somebody please go start your car and sit in it at idle for about 15 minutes and verify this. Keep the ABC on standard mode(no lights on). I'm telling you that this is not a problem...Goliath and I cannot have the same fault with our vehicles. And it isn't a drop...it's a very controlled settling...almost the same as if you set the car height to its highest and then pushed the ABC button to lower it. I have 20's on my car and there is no issue of rubbing whatsoever at anytime.
Usually the system gets metal particles in the lines and control blocks from the pump. The little pieces of metal get caught around the seals and eventually the little pieces of metal will take out the pump. Once the pump fails, it will introduce a lot more metal into the system that is very hard to get out and will take multiple flushes to get the system clean, If the system is not completely clean, you will take out another pump and you will have all the other issues related to the failed pump.
