CL-Class (W215) 2000-2006: CL 500, CL 600
Homelink????
Old Feb 22, 2008 | 05:22 PM
kineticBENZ's Avatar
03 CL 500 sport, 97 Widebody NSX-T, 04 996 C4S, 02 528i sport, 06 GSX-R 600
Homelink????
anyone know how to set the buttons on the rearview mirror to read the signal for my garage door???
Thanks a million!!!
Old Feb 22, 2008 | 06:16 PM
anyone????
Old Feb 22, 2008 | 06:26 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Please give it more than 45 minutes between posts to get an answer. If you need to pass the time I'm sure its explained in your owners manual. Make sure you have it as well as your garage door opener manual. Another reference would be found by searching MBWorld. That question has come up numerous times for different MB models.
Old Feb 23, 2008 | 10:25 AM
skaminer's Avatar
15 cls 550
you have to clear the memory before you program it (even the first time). I can't tremember exactly how you do it (I think you hold 2 buttons down for some period of time). It tells you how to clear the memory in the manual; it just doesn't mention that you have to do it before you first program the buttons.
Old Feb 23, 2008 | 10:37 AM
Car didn't come with a manual... and a search came back with only one find... a for sale ad.
Sorry.... I dont have a lot of free time to jack around on the computer so I post when I can.
Old Feb 23, 2008 | 10:40 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I just typed in "homelink" into the search function and it showed 18 pages.
Old Feb 23, 2008 | 10:57 AM
skaminer's Avatar
15 cls 550
Turn electronic key in starter switch to position 1 or 2.
SimultaneousTurn electronic key in starter switch to position 1 or 2.
Hold the end of your hand-held garage door opener approximately 2 to 5 inches (5 cm to 12 cm) away from the surface of the in-vehicle remote control located on the inside rear view mirror, keeping the indicator lamp in view.
Using both hands, simultaneously push the hand-held garage door opener button and the desired in-vehicle remote control button. Do not release the buttons until completing step 4.
The indicator lamp on the in-vehicle remote control will flash, first slowly and then rapidly. When the indicator lamp flashes rapidly, both buttons may be released (the rapid flashing lamp indicates successful programming of the new frequency signal). To program the remaining two remote control buttons, follow steps 1 through 4.
To clear memory:
Simultaneously hold down the left and right side buttons for approximately 20 seconds, or until the control lamp blink rapidly. This will erase the codes of all three channels.
Old Feb 23, 2008 | 11:45 AM
To clear memory:
Thank you very very very much!!!!
Ever in the Houston area... Beers on me!!!
Old Feb 23, 2008 | 12:30 PM
skaminer's Avatar
15 cls 550
thanks
You can print out the owners manual from the mercedes website under owners online
Old Feb 23, 2008 | 08:45 PM
GGM's Avatar
GGM
2008 E350
If your garage door opener uses a "rolling code" you may want to check this thread:
https://mbworld.org/forums/showthrea...t=code+rolling
Hope this helps.
Old Mar 7, 2008 | 10:46 PM
SpiderAce's Avatar
S63 AMG Coupe AMG GT55
It took probably a full minute before the car "paired" with the remote,, so you may have to hold both the car button and the remote button down longer then "you feel you should have to". Once paired with the remote it was a snap recognizing the rolling code door opener.
