CL-Class (W215) 2000-2006: CL 500, CL 600
How can I jumpstart the car?
Old May 11, 2008 | 09:54 AM
rzv_zxz's Avatar
CL600 AMG optik
My car has no more battery. I opened the door with the small key, but I can't open the trunk with that key... I don't know why it doesn't fit in there.
Is there any way to jumpstart the car from the engine?
Old May 11, 2008 | 11:24 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
I know of no way to do so as I have been told that by MB. However, your key should open your trunk. I just tried my '02 CL 500 and found it to be a little tricky. Once in place, turn it all the way clockwise and then push the button up. I know you said it won't fit but try it again.
Old May 11, 2008 | 02:05 PM
rzv_zxz's Avatar
CL600 AMG optik
I solved the problem
Old May 12, 2008 | 07:05 AM
Jud Chapin's Avatar
Good deal! What happened so that others may learn?
Old May 12, 2008 | 09:34 AM
rzv_zxz's Avatar
CL600 AMG optik
On the passenger side, at the feet it's a "+" and a "-" so you can give the car energy from other car or other battery. After I had enough power I managed to open the trunk from the button and after that I jumpstarted the car from other car.
Old May 12, 2008 | 10:34 AM
Jud Chapin's Avatar
I don't understand "passenger side at the feet". Can you be a little more descriptive as to where these post accesses are?
Old May 17, 2008 | 06:45 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
show us a picture
Old May 22, 2008 | 04:41 AM
rzv_zxz's Avatar
CL600 AMG optik
Under the dashboard... where the passenger keeps his feet. I will make some photos.
Old Sep 24, 2009 | 03:22 AM
CL500's Avatar
11' E220 CDI
Does anyone have any more info on this? Pictures? How to do it?
Old Nov 4, 2013 | 02:09 PM
MiguelsC2CL's Avatar
2002 CL 500
You have to tap into the hot cable running under passenger side carpet. You have to open the insulation and supply power to the cable. Then you can open your trunk etc..
