CL-Class (W215) 2000-2006: CL 500, CL 600
02 CL500 ABC Pump
Old Jun 21, 2008 | 09:34 PM
sagaboy13's Avatar
2002 Mercedes CL500
02 CL500 ABC Pump
Hi, I have a 02 CL500 I recently had my car serviced an was informed that I need to replace my ABC pump and it makes a noise. The ABC is still working correctly bu there is a message on the dash to visit workshop in regards of the ABC....do i need to get a new pump or just flush out the hydraulic fluid and change the filter? If I have to buy a new pump, are there any recommendations of where to get one other than the dealer?
Thanks for your advice/help!
Old Jun 22, 2008 | 01:15 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Ugh, that's bad news. No, that's horrible news. Get ready to throw down around $3,000 for the pump change and fluid flush. I would have them flush multiple times because it will kill another pump if they don't get all the contamination out of the system.
Old Oct 21, 2009 | 04:21 PM
endri sallata's Avatar
sl600 2005
i have the same problem my abc pressure is fine but a dry noise coming from the pump.i tried another pump (used)and same thing.maybe new filter or what/
Old Oct 25, 2009 | 12:11 PM
mrrippey's Avatar
you cannot have this car with out an extended warranty.....it pays for itself on one big issue
Old Oct 29, 2009 | 11:01 PM
BenjaminSimon's Avatar
2004 SL500, 2014 S550
I am having similar issues. I had the “Service ABC” message a few weeks ago. Long story short, there was a $1.50 gasket needing replaced with $400 in labor. (Yes, thank God I have an all inclusive extended warranty)
Ever since then, the power steering "groans" when turning. If I turn too fast, at slow speeds, the steering becomes resistive. However, this does not occur all of the time. Also, the car does not seem to rise up and down as fast when pressing the ABC leveling button (For lack of a better name).
No codes or messages.
Does this appear to be a weak pump?
I still have over 40 months and 41K miles of warranty. J
Old Oct 30, 2009 | 07:29 AM
SLCL's Avatar
CL55, SL500, E350
Sorry for the off-topic but can you tell what warranty are you having? Thanks.
