CL-Class (W215) 2000-2006: CL 500, CL 600
HELP!!!!!!!!!!ABC SUSPENSION
Old Jun 27, 2008 | 12:01 AM
jammal8306's Avatar
mercedes cl500
well i think i blew the air suspension compressor . i was sittin in the car and all of a sudden i heard a big thud , or like a pop . then i moved the car back and theres fluid every where . the abc warning also came up on the cluster . but the ride height did not drop . also cant raise or drop the suspension . if anyone knows what exactly happened please let me know . thanx
Old Jun 27, 2008 | 01:00 AM
fixer's Avatar
r 320cdi
One of the suspension high pressure hoses has split, only way to resolve the issue is to get it to the dealer and have the hose replaced. I take it it is the front left where the leak is.
DO NOT DRIVE TO THE DEALER. If the suspension is low, the wheels on a lock will damage the wings. Sorry Jammal, you will have to have it recovered, unless you want to damage your wings.
Old Jun 27, 2008 | 01:12 AM
donjuan45i's Avatar
S500
man that sucks I keep my fingers crossed that I wont run into this, do you think your wheels maybe contributed to the wear and tear on it? I have 18" amg's and want to go bigger like to a 20" brabus but im worried that after dropping some nice dough on wheels I will soon after be confronted with a visit workshop indicator on my cluster
Old Jun 27, 2008 | 01:28 AM
jammal8306's Avatar
mercedes cl500
but the car is not low . it never dropped . should i still have it towed ?
Old Jun 27, 2008 | 07:43 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
There is a recall on the hose. I would not drive the car as fluid from the ABC could spray onto something hot and cause a major problem. Call your MB dealer and see what they have to say about it.
Old Jun 28, 2008 | 03:16 AM
jammal8306's Avatar
mercedes cl500
thanx a lot guys u were right it was a hose . if that hose is on recall should mercedes replace it for free ?
Old Jun 28, 2008 | 03:19 AM
jammal8306's Avatar
mercedes cl500
dude i highly doubt the wheels had anything to do with hose spliting . i think it was just wear and tear
Old Jun 28, 2008 | 03:22 AM
jammal8306's Avatar
mercedes cl500
i only have the wheels on for like a month plus jud just said theres a recall on that hose . so u should be fine wit 20's
Old Jun 28, 2008 | 10:14 AM
Jud Chapin's Avatar
Check the recall out:
http://www.allworldauto.com/recalls/...all_44343.html
It says it pertains to the '04 but I know it covers more years as they replaced mine on my '02.
Old Jun 28, 2008 | 01:17 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Don't be surprised if they tell you the hose has already been replaced and your stuck with the bill for the hose. A failed hose can knock out the ABC pump. The hydraulic fluid keeps the pump lubricated and without lubrication the pump dies. I think my old CL blew just about every ABC hose on the car. It was in the shop, for what seemed, every few weeks for blown ABC hoses.
Old Jul 11, 2008 | 01:18 AM
pocket's Avatar
2000 cl500
abc problems
My car is pushing out fluid from the vent holes on the fluid tank. ??? the shop could not find anything wrong even though it has happened more than once. They cleared the codes that read low preasure although one would think too much. Anyone have any thoughts??
Thanks,
Pocket
Old Jul 11, 2008 | 01:20 AM
pocket's Avatar
2000 cl500
mine is cl500 2000 and they replaced mine free.
