ugly sound from belt
when the car is cold i would here a ugly sound from the belt area.(sound like if you were to take a nail and move it up and down on a chalkboard)
but as soon as the car warm up sound goes away.
i went to autozone and bought belt dressing (no help at all)
i look at the belt look good no crack
has anyone ever has this problem in the pass?
2003 CL55 stage 4 Renntech and 2006 CLS55 AMG
Thought thats what it was. I've done other vehicles, but I haven't changed on on a cl before, so not sure what it takes to do it. It would depend on where on the front of the engine its located and what has to be taken off to remove it. A chev truck takes about 15 minutes, others could take hours if the rad has to come out ( which isn't likely, just an example).
What does your invoice say for parts and what (hours) for labor?
You could also give another dealer a call and ask them what the book rate to re and re a belt tensioner for your vehicle. There are posted "book" rates for various items. See if what you find out makes sense compared to what you were charged.
the parts cost 192.00 wholesale price
labor is 4 hrs @85.00 (but really about a hr and half)
most all the dealer where im at are all the same when it comes to labor
it is just the parts that are different
I look at the tension roller it look easy to get in there
there is enough space and you dont have to remove the rad
the only think is you might need a special tension tool make the job easier
i see give about a week i might do this myself
and if i do i take some picture and post it
i got my abc change at 70k under warranty
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
As I was reading the problem, it sounded like a tensioner bearing. It looks like all turned out fine. Keep that baby in shape!
http://www.rockauto.com/catalog/raframecatalog.php
from 122.00 to 233.00 aftermarket
http://mercedespartssuperstore.com/
112-200-0970 OEM 196.00
2004 CL55
OHhhh man these engine prices! Pray nothing ever should happen to your engine!
Engine, cl600, s600 - 12 cylinder, 5.5l sohc, gas - 12 CYLINDER, 5.5L SOHC, GAS 03-06 $60,600.00
Engine, s430 - 8 cylinder, 4.3l and 5.0l sohc, gas - 8 CYLINDER, 4.3L and 5.0L SOHC, GAS 02-06 $24,470.00
Engine, cl500, s500 - 8 cylinder, 4.3l and 5.0l sohc, gas - 8 CYLINDER, 4.3L and 5.0L SOHC, GAS 02-06 $32,780.00
Engine, s55, cl55 - 8 cylinder, 5.5l sohc - 8 CYLINDER, 5.5L SOHC 03-06 $56,020.00
