CL-Class (W215) 2000-2006: CL 500, CL 600
Chip
Old Sep 17, 2008 | 11:02 AM
Bo CL500's Avatar
CL500
Chip
Do any of you guys have any experiance in putting a chip in your car to give it more horse power, take the top speed limit off and improve your gas milege? Does it work and is there ANY negative side effects?
Old Sep 17, 2008 | 11:50 AM
Patentmat's Avatar
Haha I remember doing that back about 10 years ago. I had a Lincoln Mark VIII and once it was chipped (with a "SuperChip" it was called) it was actually noticeably quicker and would leave about 5 feet of rubber on the pavement between the 1-2 shift, and it was an automatic. Had that chip for a few years with no ill experience. It really depends car by car though, some are already pretty well optimized.
My story aside, there was a thread about this: https://mbworld.org/forums/showthrea...hlight=chip+cl but it is about 3 years old, so if anyone has done this recently I would be interested to know more about it too.
Old Oct 16, 2008 | 06:09 PM
Bo CL500's Avatar
CL500
has anyone else put a chip in their car?
Old Oct 16, 2008 | 10:52 PM
Baby ///M3's Avatar
Mercedes CL500
I think the word "chip" may be an old term, as cars nowadays technically can't have their engine management map altered with a simple swap of chip like the older models do.
That being said, I still have an older BMW that I tinker with from time to time. As far as I know, even the BMW 3 series could not have its engine management altered with a chip after the 1996 production year. Instead, a software upgrade was needed for minor performance improvement. I would therefore imagine that Mercedes has followed the same, if not more advanced pattern on its cars.
I believe you may have your engine software upgraded by an aftermarket tuner. The results are generally inconsistent depending on whom you speak with. I have replaced both the engine chip and transmission chip on my BMW with reputable BMW tuners (J. Conforti and Dinan) and frankly, the psychological effects were much more apparent than actual performance increases.
Also, you'll want to take in consideration that any power gain advertised by chip manufacturers may be misleading. For instance, if XXX company states that there will be a 20hp gain on a car that has 300hp in stock form, it doesn't mean that you'll get the full 320hp with a chip. The reason is simple, if the chip is giving the gain only at a RPM point where the car isn't making its full power, then the advertised result can be misleading.
Given the complicated nature on modern cars, I can only bet that the science involved in it is probably much more in depth than I've ever known.
Jon
Old Oct 17, 2008 | 11:01 AM
Bo CL500's Avatar
CL500
So I take it that it is not worth fooling with?
Old Oct 17, 2008 | 08:30 PM
Baby ///M3's Avatar
Mercedes CL500
Actually, whether it's worth it or not is really up to the person who makes the choice.
If I were you, I would spend that few hundred dollars on a Sprint booster device instead.
Jon
Old Oct 18, 2008 | 04:22 PM
Bo CL500's Avatar
CL500
Jon
Whats that?
Old Oct 19, 2008 | 05:26 PM
Baby ///M3's Avatar
Mercedes CL500
Sprint booster is a device that adjusts the sensitivity of your electronic throttle.
Notice that the CL often "lags" when you want to give it a go on highways? It's due to the fact that unlike older cars that utilize throttle cables, newer Mercedes throttle is controlled by electronics. The drawback is that usually, the electronic mapping is rather conservative and computer often reacts very slowly when you put your foot on the gas pedal.
Sprint booster essentially minimizes this problem, just like how one can "tighten up" the throttle cable for a more instantaneous response when you go off the line. Instead of getting the full throttle when you need to press that pedal to the metal, you're getting the full feed by only having your foot 1/3 of the way.
I really like the convenient and quicker response that this device has provided. In my opinion it's more worthy than a computer software upgrade.
There are of course, pros and cons about this device. For your reference here's a huge discussion/debate about it on another MB forum. You can also read about my feedback about this device toward the back of the discussion.
http://www.benzworld.org/forums/r170...-facts-15.html
Jon
Old Oct 19, 2008 | 05:55 PM
Bo CL500's Avatar
CL500
Jon
Thanks. a friend of mine told me that car adjusts to the way you drive, meaning if it notices that you drive fast and you keep on stepping on the throttle a lot it wil know adjust to that type of driving so it will downshift faster. Is this true or is this just in my head since i sometimes i feel the car shifting quicker?
Old Oct 19, 2008 | 06:08 PM
Bo CL500's Avatar
CL500
Old Nov 9, 2008 | 04:12 AM
Bo CL500's Avatar
CL500
Just to update you guys I ended up getting the chip in my car. The response is a lot faster and the MPG improved. Price was $840.00 and it took and 45 min
Old Nov 9, 2008 | 08:56 PM
Baby ///M3's Avatar
Mercedes CL500
Oh wow...
Since you're close we may be able to see how my Sprint Booster stacks up against your chip upgrade one of these days.
Jon
Old Nov 9, 2008 | 11:05 PM
illmeth0d's Avatar
2000 S430
what chip did you get?
Old Nov 9, 2008 | 11:41 PM
Bo CL500's Avatar
CL500
i used power chip
Jon, where are you at? and whats a sprint booster?
Old Nov 9, 2008 | 11:52 PM
Baby ///M3's Avatar
Mercedes CL500
I am in San Gabriel Valley.
If you scroll 4-5 posts upstairs, you'll be able to read about the SB device.
Just to clarify, Sprint Booster does not increase a car's overall performance but rather, it helps the car react better (it's like having a horse that can run fast when you simply whispers to its ears rather than having a horse that can run fast only when you whoops its *** really hard).
Jon
Old Nov 10, 2008 | 10:54 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
We have a very nice ECU set up for the 500. We are yielding roughly a 10% increase in hp/tq, broaden the power band and remove the limiter. Overall we really reveal the sporting nature of these cars.
Old Nov 10, 2008 | 02:59 PM
Bo CL500's Avatar
CL500
Jon
it will help if i can read, hugh?
