White LED License Plate Lights
i read that already you still need resistor.
my question what ohm resistor should i use?
and can i cut the wire and connect the resistor like that or
i have to connect the resistor bulb are at.
http://superlumination.com/images/au...otector_wm.jpg
Sorry if it didnt help.
here is the link thhat it show you how.
this link inform you to use only one resistor but it is not true
becuase i have to use 2 for my
hope this help
have fun take about 20min you be done
http://www.benzworld.org/forums/w210...ll-can-do.html
i use 100w 10ohn on each side i just t-tap the connector and that it
hope this help
hope this help
I've read though that (5 pages) but it seems like some of them got trouble with burning their wire or the clear housing . Did you check your ??? So you have to use 2 resistors ?? Did u ever try 1 resistor before u used two ? what happened when u install only one resistor?? flickering??
i try one resistor 1st just one led came on and dash light came on
so i put 2 resistor both led light up ran for like ten min no burning smell
i think the only time it burn if you use 2watt 22ohm it burn becuase i try that 1st that what happen so i just up the resistor
