CL-Class (W215) 2000-2006: CL 500, CL 600
ABC problem on 02 cl500 pllllllllzzzzzz help :)
Old Jan 16, 2010 | 07:43 PM
firasomran's Avatar
02 cl500
i have a 02 cl500 and i am having this problem when i leave the car for a while (4 hours or more approximately) i find it leaning from the right (front and rear but especially from rear) and when i put it to drive i feel the car being lifted by it self without using the lifting button..... i changed the sensor and the valve and i checked the fluid but same problem.... i heard that the pump may need to be replaced, but am really confused about paying big amount on a new pump cuz i till now payed enough
so plllllz any advice from someone had the same problem
and plllz be serious cuz if it's too much expensive am thinking of selling the car though i really like it but i can't afford fixing it.....
Thanks in advance
Old Jan 16, 2010 | 07:56 PM
firasomran's Avatar
02 cl500
here are some pics of the car.....THX
Attached Thumbnails ABC problem on 02 cl500 pllllllllzzzzzz help :)-img00044-20100116-1428.jpg   ABC problem on 02 cl500 pllllllllzzzzzz help :)-img00045-20100116-1428.jpg   ABC problem on 02 cl500 pllllllllzzzzzz help :)-img00042-20100116-1427.jpg
Old Jan 16, 2010 | 09:25 PM
Ifari's Avatar
2000 CL500 1992 300SE
Was an ABC operational (RODEO) check done to determine that a new pump was needed?
If not, then first have an ABC fluid flush and RODEO done and see if that helps.
Old Jan 16, 2010 | 09:48 PM
firasomran's Avatar
02 cl500
yes i think i did the rodeo check... am sorry am new in this site but what do you exactly by the ABC fluid flush ??
Old Jan 16, 2010 | 10:20 PM
Ifari's Avatar
Flush out the old fluid and put in 10 litres new fluid.
If you did a rodeo check, you'd remember as it can only be done at the dealer on the STAR DAS.
Old Jan 17, 2010 | 04:48 PM
Bo CL500's Avatar
CL500
mine has the same problem, i took it to the shop and they told me to leave it a lone since im not getting any error messages
Old Feb 1, 2010 | 03:44 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
This sound like either a valve block or the pump failing. Is the pump continuously running.
If you can't afford to fix this problem, this may not be the car for you.
No matter how cheap these cars are to buy, due to depreciation, they still are $100K + cars, with expensive service costs.
Old Feb 3, 2010 | 01:06 AM
armasace's Avatar
02 CL 500
I just had the same problem with my car about 3 months ago. I started with the ABC flush, that didn't work. Next is the valve block and then pump.
Total cost with labor about $3000+. Now ts works great!
Old Mar 22, 2010 | 12:15 AM
Viet_Amg408's Avatar
Pinto
all 4 wheels strut drop like dat?
Check List.
1st: Very important that your abc/ps fluid resevoir is up to level..
2nd: check visual leak on all strut.
one or all your strut leaking? can you see any visual leaks around the strut?
if not sound like you need front and rear valve block.
flushing system not going to help because your car obviously drop dramaticly within 4hrs...
flushing/rodeo bullcrap.. is not going to help.
it make sense if when you have a slow internal leak(no visible strut leak) ..possible the valve not close properly due to stuck or not close completely...
front valve block locate left front behind front bumper each about $1500. plus labor.. ummm....$$$$ It should only takes 2hrs to do...
Rear valve is bottom rear....parts cost about the same.. and it takes 1hrs or less to replace..
you looking about 4-5k in repair bro...
unless you find a personal mechanic ...(if you in my area.i'll do it for you)
good luck...bro
Old Mar 31, 2010 | 09:41 PM
mikecl600's Avatar
05 cl55
hello everyone im new here i been a mercedes tech for years and now have my own shop i have a cl500 and i have done more ABC work then i can count if any one needs help with any abc problem let me know i olso have 2 abc pumps and 2 valve blocks for sale real cheap...
Old Mar 31, 2010 | 10:49 PM
Pinto
ur profile say u drives: cl600
Old Apr 22, 2010 | 11:13 PM
mikecl600's Avatar
05 cl55
i have a 500 and a 600
Old Apr 23, 2010 | 02:02 AM
fatmike's Avatar
CLK63 BS
I may or may not need a pump here in a few lol. Just did my rear valve block. I'll keep you in mind mikecl600
Old Nov 22, 2011 | 10:49 PM
4benz's Avatar
w215 2002 silver, e320 1999
heeelp
hello i have a related problem, i replaced the tandem pump like 3 months ago then a couple of hoases and the cars suspension works well it lower raises perfect but the car is higher on the left side by 2 cm or less
its tilted all the time while driving, paked, on and off
do you think this is normal ?
do you think they just need to rest ride hight ?
does it sound like valve block ?
thanks a million fo your help
Old Nov 23, 2011 | 08:55 AM
saintz's Avatar
GL450
There are two things that affect ride height, the sensor and the values in the computer. If the car is never level, one of those is wrong. Possibly they bent the sensor arm when working on the car. Or possibly some coding was done through SDS when working on the car and the ride height values were messed with. Either way, you probably need someone with the SDS computer to check the values and then move on to check the sensors.
Old Nov 23, 2011 | 10:48 AM
4benz's Avatar
hello thank you for your help and reply, the car was reacently diagnosed with das star at benz and everything checked out fine ( abc check), but now that you mention my indi changed the arm trhusts do you think the sensor arm could have gotten bent during this ?
if so what are my options you think?
what else could it be besides the bent arm sensor.
thanks a million for your help and time.
Old Dec 20, 2011 | 12:41 PM
babycake1's Avatar
CL 500
Cl 500
Serious issues with my CL 500/ 2005 ABC and stuck in 1st gear. Towed yesterday.
Old Mar 31, 2012 | 11:50 PM
4benz's Avatar
i am having the same issue i am stuck in first gear what should i do ???
whats is the problem?
thanks a millon
Old Jun 6, 2012 | 07:57 PM
bradster582c's Avatar
CL500
ABC Problem 2001 CL500
ABC fluid leaking. Removed pump and found that the drum behind the pulley has cracks in it. Front seal seems OK. What can I do and is there a rebuild kit or parts available for this. I may be interested in one of those pumps you have for cheap.
Old Jun 7, 2012 | 12:39 AM
City Of Roses's Avatar
CL 500
If the pump checks out ok, it's the valve block.
Old Jun 7, 2012 | 10:23 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Do not buy a rebuilt pump. Its a waste of money. Who knows how long it will last and the cost savings you will originally have will quickly vanish once it craps out and you have to install a new one. Just do it once.
R.K.
Old Jun 7, 2012 | 11:33 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I had a new pump fail after a few months. Thank goodness it was covered under their parts warranty.
Old Jun 7, 2012 | 08:21 PM
CL500
R.K.
Actually, this is an acquired car from a elderly aunt. Don't want to come off cheap, but the price tag of a new pump pretty much puts me out of the ball park. I have all the abilities to work on it, so maybe there is another option out there. Any help will be appreciated. Maybe a schematic or diagram of the pump.
Old Sep 26, 2012 | 11:55 PM
sbence89's Avatar
cl55 amg
Hello
I have a problem with my ABC as well, I just got my car like a month ago and it`s been sitting in my garage since then,I have started up my car a week ago and the drivers side has dropped down and the passenger stayed up
I do have the error message.....I will have my guy change the fluid over the weekend,but I`m sure it`s not going to solve my problem.
Anyone would know what went wrong? I would appreciate some help
Thank you
Old Sep 27, 2012 | 09:53 AM
radride's Avatar
Originally Posted by sbence89
Hello
Thank you
Valve block, pump, sensor etc... To many possibilities. Just get it checked out. It could be a $100 fix or a $3000 fix. You'll find out soon enough.
R.K.
