CL-Class (W215) 2000-2006: CL 500, CL 600
2003 CL500 ABC Fluid Leak
Old Mar 15, 2010 | 09:30 PM
TJ Esquire's Avatar
2003 CL500
I have a 2003 CL500. I've been having an ABC fluid (Pentosin CHF11S) slow leak, that's getting worse! Fluid runs out over a matter of a few days...and the car becomes uncomfortably low, 'very low'! I refill the abc resevoir, and the car raises back up when I cut the engine on. A friend of mine says it sounds like a high-pressure valve/hose leaking (there is, of course, liquid visibly leaking underneath the vehicle, and running off the oil pan near the front driver-side of vehicle). I can actually hear it squirting....any idea if this sounds like a pump problem or a hose/valve issue?
Old Mar 15, 2010 | 10:52 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Take it in asap and get it fixed. The repairs will only become more expensive if you wait. You could destroy the pump running it without fluid. I hope you have not already done so.
Old Mar 15, 2010 | 11:57 PM
callchuck's Avatar
2020 GT R Pro
You have a ABC Main line leak. Is your leak in front of the transmission. You need to replace line very expensive and 15 hours of labor to repair. If you get air in your pump you will trash that also. There was a recall on some of those lines make sure your car was not one of them. If so make MB pay for it.
Old Mar 16, 2010 | 01:06 AM
TJ Esquire's Avatar
2003 CL500
Wow! Sounds expensive...I'm taking it in this week. Thanks for the feedback...
Old Mar 16, 2010 | 01:11 AM
TJ Esquire's Avatar
2003 CL500
@Chuck- to answer your question; yes, it leaking directly beneath the resevoir, underneath that area.
Old Mar 16, 2010 | 07:52 PM
Momentum123's Avatar
I bet you need a tandem pump. It supplies
pressure for the ABC system and the power
steering, hence the name tandem. $2500 Installed at the dealer
or can by pump for $900 I think possibly at Arnotts.com or
online EBAY or such. It is a LUK brand pump usually available
Brand new aftermarket for $900 or so.
Old Mar 16, 2010 | 11:02 PM
callchuck's Avatar
2020 GT R Pro
That is correct about the tandem pump. If you sucked air into it you may destroy the pump. You can use a air compressor connected to a clean raditor hose small enough to force 1 b or 14.5 PSI into the resivior to pump the new fluid into the pump before you crank it up, so you do not suck air into the new pump.
Old Mar 17, 2010 | 03:56 AM
TJ Esquire's Avatar
2003 CL500
You guys have been very helpful! Thank you...I'll have to bite the bullet, but not as hard, considering this great data!
Old Mar 17, 2010 | 08:43 PM
Ifari's Avatar
2000 CL500 1992 300SE
If the car is raising up upon start up after you top up the ABC fluid, then it is likely the pump is still good. Change the hose, top up the fluid and then see how things go before changing the pump, it may not be necessary.
Good Luck.
Old Mar 17, 2010 | 08:48 PM
callchuck's Avatar
2020 GT R Pro
I have a 600.... not sure how hard the hose is to change on the 500 but the 600 you need to raise the motor and drop the transmission to get the new line in. I hope the 500 hose is easy to replace.
Old Mar 17, 2010 | 08:53 PM
TJ Esquire's Avatar
2003 CL500
I'm taking it in tomorrow. I'll be going the pressure-hose route first. Let's see what happens. Thx!
Old Mar 17, 2010 | 09:03 PM
Ifari's Avatar
Buy the MBZ STAR SERVICE Service Manual Library DVD for the 220/215 Model Mercedes cars when you're at the dealer.
This $100 resource will be the BEST money you'll ever spend on your car.
It has ALL repair, diagnostic, parts function and location info, as well as DTB and electronics info etc. for your car and the dealer will realise you are not the average customer.
The MBZ techs use the same DVD info for their job and this can allow you, or any garage you choose to work on your car, to understand it far more easily.
Old Mar 18, 2010 | 08:28 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Agree 100% on the DVD. However, I'm not sure you can get it from your stealer. If you can't, call 1 800 for-merc (USA home office) and order it.
