Possible $30 ABC fix..... need people to test
Got me thinking a rubber coil spring donut spacer would prevent the car from sinking, like this:
http://www.summitracing.com/parts/LNG-61140/?rtype=10
(see the picture of the spacer installed WITHIN THE COILS of the white spring)
Here is a similar spacer for $6.99 at Amazon....
http://www.amazon.com/Superior-18-19...=pd_sbs_auto_1
4 of these would be under $30....
Before you say "this wont work" note these are SPECIAL spacers, that are split for easy installation and with grooves on both sides , to fit in between the coils and keep the car from laying on the ground. These are not the typical spacers that only go on the top or bottom of the spring, these actually fit in BETWEEN the spring coils of the ABC strut.
Now, this wont "repair" your ABC to proper operation, and the ride will be stiff, but it should give you enough ride height to make your car drivable again, a cheap fix without spending thousands of $$$.... but I need someone to test my theory and see if this would really work.
Anyone with a failed ABC setup willing to try?
NOTE: Longacre sells MANY spacers, some without grooves on both sides, and I may have not linked the correct part number, so dont just buy the one I linked at Summit. You will need the spacer with grooves on BOTH sides that fits between the coils. I would recommend removing the wheel, sliding the dust cover on the ABC strut up to reveal the spring, and then measure the space between coils to be sure you order the correct sized spacer. Mr. Gasket also sells one with grooves on both sides (Mr Gasket part # 1287)
good luck...
Not everyone has the $2000-4000-8000 that it often costs to repair ABC, and it is condescending to others to say "just buy a honda" if you are already "stuck" in this situation with no options.
People use hardware store washers, not designed for suspension lowering, to lower their car....so using spring spacers (which ARE designed for the intended use) to raise it is no worse or different... the "how can you defile my precious German engineering" folks need not apply.
I did not post this for people to "poo poo" on the idea, its posted to help people stuck in a jam of an undrivable car and/or repair bill they cannot afford
