CL-Class (W215) 2000-2006: CL 500, CL 600
oil leak
Old Feb 4, 2011 | 12:50 AM
droc112's Avatar
cl600
oil leak
hey guys is there any known issues with the cl600s or 500s havin a oil leak problem? im seein a oil on the ground and it looks like its getting worse
Old Feb 4, 2011 | 02:48 AM
s5benzo's Avatar
W221 2013 S550 Rwd, W221 2010 S550 Rwd
what year is your cl600? im guessing 01-02? the 500's have a bullet proof motor, the non turbo v12 had some serious oil cooler issues. the oil cooler plate sits right in the middle of the engine between the cylinder heads. this is probably what is leaking. this is a very common and really expensive repair because the heads have to come off. not a rare issue if you have a n/a v12. the part cost around $300-$400 ...but the labor is in the thousands, this job is very labor intensive as the top half of the motor comes apart. if this is an 03 or newer the biturbo motor is way more reliable compared the non turbo, but could have oil line from turbo leaking or the oil cooler...which was better placed and designed on 03 and newer. let us know what you find out, goodluck
Old Feb 26, 2011 | 01:48 PM
droc112's Avatar
cl600
oil leak
hi thnx 4 the insight i have my cl at the shop as we speak and it turns out my leak is comin from a head gasket its leakin from the top of the motor in the back and runnin down the the side of my trans
Old Mar 1, 2011 | 01:53 PM
s5benzo's Avatar
Droc any updates on what the problem is ?
Old Mar 5, 2011 | 12:49 AM
droc112's Avatar
cl600
yea bruh its comin from my head gasket...waitin 2 hear what that tab is gonna b......yo have u heard of anybody having a head gasket put on?? i know i heard of the oil cooler goin but this leak is up top and i seen where it is
Old Mar 5, 2011 | 12:57 AM
s5benzo's Avatar
its strange that they found the head gasket leaking. thats not very common. the oil cooler on the non turbo motor sits between the heads ...thats very notorious for failing and causing massive leaks. the heads come off to change the cooler, so i suggest if theyre replacing the leaking head gasket(s)....best change the oil cooler plate for preventative maintenance. this is a very costly job...i think at least like 4-5 thousand with parts and labor depending on where the work is performed. from what your describing i think its the oil cooler leaking but i could be mistaken. take care of it be4 leak becomes massive. goodluck , keep us updated
Old Mar 5, 2011 | 11:38 AM
droc112's Avatar
cl600
hey sfive should i tell him to change the oil cooler also since he already have to take the heads off? will the cooler be right there once he take the heads off
Old Mar 5, 2011 | 12:30 PM
s5benzo's Avatar
I'm guessing your car is an 01- 02 600 right ? If its the non turbo motor than yes , the oil cooler sits exactlyin the middle of the heads . Oil cooler is a known failure, I would change it.
Old Mar 5, 2011 | 11:20 PM
saintz's Avatar
GL450
I've seen a lot of valve cover leaks, but not head gasket leaks. Head gasket normally means coolant in your block, which means white smoke and foam/yogurt when you open the oil plug.
Old Mar 6, 2011 | 09:51 PM
droc112's Avatar
cl600
ok cool thnx! i'll keep u guys posted...also one more thing s5 where can i purchase the oil cooler besides the stealership....lol...and is there anything else i should change while he has the motor open?
Old Mar 6, 2011 | 09:53 PM
droc112's Avatar
cl600
also s5 u dnt think its the head gaskets? plus i dnt c any smoke and it aint no yogurt like stuff in there...i dnt believe it is i think its the oil cooler also!
Old Mar 6, 2011 | 10:13 PM
s5benzo's Avatar
Parts.com lists an oil cooler for your 600 around $308.00 . Replace head gaskets anyway since heads are coming off , valve cover gaskets etc... whatever is preventative maintenance that is easily changeable while all taken apart just change .... Goodluck , keep us updated
Old Mar 25, 2011 | 09:46 AM
grane's Avatar
GLK350, SL63 AMG
+1 check the valve gaskets first and replace these since your engine is older. Good advice for all engines. Just this and all the breather tubes replaced with plugs on my113 v8. Mileage is already up 15%!
If your in there do the oil cooler and replace those hoses!
Old Mar 25, 2011 | 10:32 AM
saintz's Avatar
GL450
The V8 valve covers leak a lot. You can normally just tighten them back down. It's only if it's really leaking or keeps leaking after you tighten that you need to replace them.
Old Mar 25, 2011 | 10:36 AM
sknight's Avatar
c200k
That sounds horrid, and frankly, disappointing. The prices charged and this nonsense continues.
Old Mar 25, 2011 | 10:52 PM
grane's Avatar
GLK350, SL63 AMG
At 104 k miles I figured it was prudent to replace the plugs, the vcgs and the hoses. Keeps the nasty oil away from the expensive spark packs. Inexpensive maintenance if you do everything at once. And have a good inexpensive indy.
Old May 12, 2011 | 03:47 AM
droc112's Avatar
cl600
oil leak
Well fellas the silver surfer is finally done...oh and it was the oil cooler like i suspected..i changed the oil cooler..valve cover gaskets...head gaskets..lower intake gaskets...timing chain and assembly..all spark plugs..thermastat..water pump..all seals...and then on top of that my tech went to do a test drive and noticed that my trans wasnt shifting right did a diagnostic and it showed that my tcm was bad..yo this car is really f%ckin expensive!! this is like havin a new motor...if one more thing go wrong its outta here! oh i 4got 2 mention this job ran me around $5000! pray for me guys...
Old May 12, 2011 | 07:33 AM
SLCL's Avatar
CL55, SL500, E350
Was your car the turbo or NA (what year model)? Talking about bad luck! No wonder these cars are dirt cheap nowaday
Old May 12, 2011 | 11:06 AM
droc112's Avatar
cl600
its a 2002 non turbo
droc112's Avatar
cl600
my bad cl600
Old Oct 25, 2011 | 10:26 AM
kfillhart's Avatar
cl600
Pictures of the oil cooler failure
Here are some pictures when I tore my V12 down last winter. !FUN, FUN, FUN! If anyone attempts to do this on their own, as I did, I'll be happy to give some tips and tricks on how to make the job a little easier and less painful.
Expect 30+ hours to do this from beginning to end
Attached Thumbnails oil leak-img_1122-1-.jpg   oil leak-img_1091-1-.jpg   oil leak-img_1092-1-.jpg   oil leak-img_1100-1-.jpg   oil leak-img_1077-1-.jpg
Old Jun 18, 2014 | 07:56 PM
RGDetroit's Avatar
2001 S600
Smile Need the tricks
Hey , I was reading this thread and at the bottom it states that some one could offer the tricks to getting this completed on my own. Any assitance would be greatly appreciated. I did not see what or where the cooler leaks from. Is it a complete remove and replace or does the small rubber gasket fail? Need help!!!
Old Jun 19, 2014 | 12:32 AM
kfillhart's Avatar
cl600
You have to buy the whole oil cooler.
What happens is the oil cooler is made in 2 pieces and the rubber gasket between the two pieces leaks. The cooler is located in the middle of the engine where temperatures get very hot. Over time the rubber gasket gets dry, brittle, and shrinks allowing oil to leak between the 2 pieces of the oil cooler. Mercedes will not sell just a replacement gasket they only sell the whole oil cooler assembly.
Old Jun 19, 2014 | 08:15 AM
RGDetroit's Avatar
2001 S600
S600 oil leak
Has anybody tried to reroute the oil lines away from this cooler to an outside or external hung cooler and not repair the engine mounted cooler? Does oil enter and exit on top or does it travel into the motor on the bottom of the cooler? Seems pretty straight forward to eliminate the issue or am I being stupid??
Old Jun 25, 2014 | 03:25 PM
kfillhart's Avatar
cl600
It would probably be hard to reroute and put in an external cooler. The 2 hoses on top of the cooler are breather lines. The oil enters and exits through the bottom, you can see where in the pictures of the engine with cooler out.
Another issue with relocating is there is coolant that runs under the cooler too. Better off replacing it or making your own gasket. If you make your own gasket I would recommend putting the cooler in water and running air into to test for leaks. It would suck to do all that work and it still leak. Getting a new cooler is safe bet. I have never heard of the new cooler leaking again but that's not saying it hasn't happened.
