Hi all,
Well yesterday I was lowering my 02 cl 600 with whats known as the spacer method. I did the front, and turned on the car to check whether the front was at a height I wanted it to be, then I got to the back, did the same thing but when I turned the car on the back was higher than before! I was shocked! What might have caused this? I added an equal amt. Of spacers..
Please advise,
Thanks,
Paul
Please advise,
Thanks,
Paul
You can't use spacers on the back. Only the front. You need to use links on the rear. If you shim the back, it makes it higher.
Currently Active Users (1)
