Problems after doing the brakes!
I replaced the front brakes and left caliper on my 02 CL500. Immediately afterward the ESP and BAS messages came on and said visit workshop. The ABS light came on also. The speedometer needle bounces around for 10-15 seconds then settles down and the ABC visit workshop comes on then and the power steering is out. The cruise control does not work, it says to visit workshop also.
Help! Is this all related to doing the brakes?
It sounds expensive just to save a few bucks on doing my own brakes.
When the speed sensor becomes implausible the system will throw the ABC/ESP/BAS errors and shut down anything that has to do with speed sensitive input such as power steering, cruise control, etc.
I would check your ABC speed sensor's located behind the dust shield on the front brakes.
Did you happen to remove the front hubs for any reason ?
As far as the cluster needle, power steering, and cruise control issues, sounds like somebody did some electrical repairs at some point but messed something up (bad solders, for example). So no, it has nothing to do with the brake job. EDIT: nevermind yes they can, abs wheel speed sensor can affect most of these.
Tbirdjpb, you may want to elaborate on what you mean when you say the power steering is "out."
As far as the ABC and power steering, I don't see how that can be related to the brake job.
See my full report and the fix here: https://mbworld.org/forums/mercedes-...ml#post4828483
Your issue definitely is mechanical and located in the hub/tone sensor/abc speed sensor on the side the bearing(s)/Race(s) were replaced.
When your car doesn't get valid speed sensor readings it goes into a disable mode and all power sensative options are turned off. So yes, your power steering while that malfunction is present is indeed not working.
