CL-Class (W215) 2000-2006: CL 500, CL 600
ABC - Drive Carefully error
Old Jun 14, 2014 | 09:57 PM
truncalep's Avatar
Cl 500
I have a 2001 CL 500 and 3 days ago got the ABC - Drive Carefully error.
I took my car in to my personnel mechanic did multiple diagnostic checks and a pressure check overnight but the car did not lower nor has a leak. He change the fluid out anyways. but couldn't figure out what the issue is. Said he thinks its the tandem pump. I took the car back over the weekend and notice that when I initially start It up the error comes up, put it in drive move a couple yards and there's a severe vibration/runbling sound almost like a dirt bike winding down for about 3 seconds and than goes away and the Error clears? But only happens when the car sits and I initially start it , put it in drive and the car moves. after the initial vibration it never comes back until I park and start it again. I was thinking maybe the airmatic pump going bad? but not sure if that would make the ABC error come on. I don't think it would be the accumulator I think that gives you a constant low rumbling noise at low RPM's. Any ideas much appreciated.
Old Jun 15, 2014 | 12:45 PM
awiner's Avatar
2003 CL55 AMG
More than likely your pulsation dampener is shot.
I would recommend checking all four nitrogen spheres. At the age of your car (whats the mileage?), my guess is your one or more of your spheres (dampeners / accumulators) are shot are about to be shot.
Old Jun 15, 2014 | 11:01 PM
truncalep's Avatar
Cl 500
106,000 miles thanks for the insight
Old Jun 16, 2014 | 04:02 PM
awiner's Avatar
2003 CL55 AMG
Around that time is when I lost my first accumulator. The second went 30k later.
Old Jun 21, 2014 | 02:25 AM
tusabes's Avatar
Mercedes
Pulsation damper is different from the accumulator (the three spheres)
At this age and mileage all of these need to be changed
But the grinding noise soon after startup is usually the abc pump
Old Jun 27, 2014 | 01:42 PM
duhdenmark's Avatar
CL600
Could you get your mechanic to give you the error codes?
Most of the time its actually pretty easy to diagnose errors in the abc system, and I am a DIY mechanic with only basic knowledge.
Low pressure will trigger an error code!
I have a link for pretty cheap pressure accumulators if you are from Europe.
David
Old Jul 11, 2014 | 03:56 PM
matias's Avatar
CL500
David
I am from europe! P.M!!!
Old Jul 15, 2014 | 04:55 PM
NRL's Avatar
NRL
CL65, FJ80, Sportsmobile 4x4, Model X Plaid
Does anything need to be drained, pinched off, or pressure released to replace the accumulators?
Do I have to bleed the whole system or is there a bleed value just where the accumulator is connected?
