CL-Class (W215) 2000-2006: CL 500, CL 600
How to Adjust/Calibrate Height Sensors
Old Apr 4, 2016 | 12:31 AM
superfast's Avatar
97 Lexus LS400, 04 Mustang, 08 Corvette Z51, 92 Honda Civic Si, 02 CL500, 03 E500
I did some suspension work on my CL500 over the weekend (replaced bottom rear strut bushings). Now the rear is sitting 3" higher than before after I re-connected the 2 rear height sensor linkages. Looks like I'll need to take the car back to the dealer for them to re-calibrate the height sensors. Does anyone know if is there a way that the height sensors can be re-adjusted/re-calibrated without using the Star software? How many height sensors are there? Is it one at each wheel? Please advise. Thank you.
Old Apr 4, 2016 | 11:23 AM
superfast's Avatar
Plutoe- Every time when the height sensor is disconnected, there's a very good chance that the car will stand unevenly so the sensor will need to be re-calibrated & it's no big deal!! Any dealers or indy shops with the SDS will be happy to re-calibrate the sensor for a fee which I have done a few times in the past. I was asking if there's another way to re-calibrate the sensor without using the software, that's all.
Old Apr 6, 2016 | 04:07 PM
superfast's Avatar
I've figured it out why the rear was 3" higher after the suspension work. It turned out I had both rear sensor's linkages installed 180 deg out. Car is now back to normal the way I like it.
