CL-Class (W215) 2000-2006: CL 500, CL 600
Air con hissing after regas
Old May 22, 2016 | 09:20 AM
gurpsingh1's Avatar
CL55 AMG
Hello all.
Just had my air con regassed. It worked for a few weeks but now there's a loud hissing sound that sounds like it's coming from the passenger side. The air con is also pumping out warm air.
Any ideas?
I have a cl55 2002
Old May 22, 2016 | 03:58 PM
Dr Matt's Avatar
05 CL65
You have a leak. Going to have to fix it and refill. Turn off your ac in the mean time.
Old May 22, 2016 | 05:09 PM
gurpsingh1's Avatar
CL55 AMG
Thanks for the reply. Is it a DIY job to find the leak?
No errors stored..
Old May 22, 2016 | 05:32 PM
ItalianJoe1's Avatar
2003 CL 600
No a leak is a mechanical problem, the car won't be able to diag where it is. Most a/c system leaks are either the evaporator, or object damage on the compressor. Generally speaking you will see oil residue from wherever it's leaking. If you can't find it, it's probably in the evaporator core inside the dash. GL, I hate a/c work.
