CL-Class (W215) 2000-2006: CL 500, CL 600
My passenger side rear window not working
Old 10-01-2016, 09:29 PM
Jome073's Avatar
2001 CL600 (W215) 2005 Mazda Rx8 Grand Touring
I just bought a 2001 CL600 with minor issues.
1. My passenger rear window won't go up or down
2. Driver rear window keeps creeping down every time I open and close my door.
Has anyone had these issues? Needs some help =[
Old 10-01-2016, 09:47 PM
knowbenz's Avatar
Benz
1. Need to see if motor is getting power, could be window motor or the rear window module, I have replaced both on numerous occasions.
2. Sounds like a window regulator, does it grind going up or down?
Jome073 (10-01-2016)
Old 10-01-2016, 10:04 PM
Jome073's Avatar
Thanks for replying, it doesn't make any noise or motion I tried the back seat controls, still nothing.
Old 10-01-2016, 11:07 PM
Jome073's Avatar
Do you know where the rear window module is?
Knowbenz
Old 10-02-2016, 12:58 AM
knowbenz's Avatar
Benz
Knowbenz
Under the right rear seat cushion.
Jome073 (10-02-2016)
Old 10-02-2016, 01:26 AM
Jome073's Avatar
Is it easy to remove? The seat cushion
Old 10-02-2016, 01:29 AM
knowbenz's Avatar
Benz
Yeah, it's been a few months since I pulled one but I want to say there is a release tab towards the outer side of the front of cushion, push it up and pull the cushion straight up.
Old 10-02-2016, 01:31 AM
Jome073's Avatar
Ok cool I will try tomorrow. Thanks for your help Know Benz
Old 10-02-2016, 01:34 AM
knowbenz's Avatar
Benz
Hopefully this helps, M10/5 is left side and M10/6 is right side
Old 10-02-2016, 07:56 AM
Jome073's Avatar
Thank very much for your assistance. This will definitely help.
Old 10-08-2016, 01:38 AM
Jome073's Avatar
The rear window is getting power I can hear it trying to move it's making noise but it's not moving. The driver rear window keeps creeping down every time I open and close the window. Does anyone have this same issue? Need some advice
Old 10-08-2016, 11:38 AM
knowbenz's Avatar
Benz
Unscrew the motor and pull it off. See if motor turns by itself. With the motor out you can move the window up and down by hand as long as regulator is good. if it's stuck you need a regulator
Old 10-08-2016, 11:50 AM
Jome073's Avatar
Okay thank you. Do you know of any step by step instructions to do this. I'm new to this car I just don't want to break anything if I am going to do it myself.
KnowBenz
Old 10-08-2016, 02:37 PM
knowbenz's Avatar
Benz
KnowBenz
The back seat lifts out, can't recall the clips and screws off the top of my head, won't be in shop until after weekend but I'm sure there is a video on youtube somewhere
Old 10-08-2016, 02:42 PM
Jome073's Avatar
Ok thank you for your help I appreciate it. I will give you a progress if the issue is resolved.
thanks KnowBenz
Old 10-19-2016, 11:23 AM
Jome073's Avatar
Good morning KnowBenz
I just got my car ba k from the dealership and they did confirm that it was rear window module. It cost $761 for the part now just waiting for the to come in from Germany.
Old 10-19-2016, 10:15 PM
knowbenz's Avatar
Benz
Nice, seen several of those go bad
Old 10-19-2016, 11:37 PM
Jome073's Avatar
Well I found out that I was way overcharged for the part. I got a used part for $64.78 I immediately returned the part with no hitch just have to wait for it to ship but worth the wait.
booesq (11-01-2016)
Old 10-19-2016, 11:41 PM
knowbenz's Avatar
Benz
Even better, so long as it works. Worth the gamble at that price though.
Old 10-19-2016, 11:45 PM
Jome073's Avatar
Yeah for real, the one I bought was from eBay even with a warranty. I bought another one just in case. Ha
Old 10-20-2016, 09:37 PM
Jome073's Avatar
Well no go even though I saved money with the part I still have the same issue after I replaced the rear window regulator. I can hear the window trying to go down, just seems like it's jammed. And my driver's side still stays down even after I close it. Looks like I'm going to need to bring it in a shop.
Old 10-20-2016, 11:24 PM
knowbenz's Avatar
Benz
wait, what? I thought you took it to the dealer? You replaced the regulator or the module under rear passenger seat?
Old 10-21-2016, 01:46 AM
Jome073's Avatar
Yes I did . It didn't do anything.. issues as before
Old 10-21-2016, 07:57 AM
knowbenz's Avatar
Benz
You did what?
Old 10-21-2016, 08:48 AM
Jome073's Avatar
I changed the rear window regulator underneath the passenger seat in the back. The black box that you showed me in the picture.
​​​I did take it to the dealer and they said it was the same issue, the rear window regulator. They where going to charge me over a thousand dollars for parts and labor. Instead I bought a used part on line for $46.00 and it myself. The issue still remained with the rear passenger not going down and the driver rear window slightly going down every time I close my door.
Do you think I bought a bad rear window regulator?
Quick Reply: My passenger side rear window not working
