CL-Class (W215) 2000-2006: CL 500, CL 600
Starter replacement how to.
Old Apr 27, 2017 | 09:42 PM
BrileyR's Avatar
2005 C230 Sport
Does anyone have experience replacing a starter on a CL600? I crawled under the car for a while tonight trying to figure out how to go about it. Wanted to get tips from anyone who's done it before.
Thanks.
Old Apr 28, 2017 | 12:04 PM
Welwynnick's Avatar
2006 S600
Is yours an NA or TT?
The latter is more difficult.
Are you sure it's a starter problem? It could be a battery strap or the earth strap. Make sure they're properly bonded first.
Nick
Old Apr 28, 2017 | 11:09 PM
BrileyR's Avatar
2005 C230 Sport
WDBPJ78J32A026119
NA, Definitely the starter.
Thanks.
Old Apr 29, 2017 | 07:32 AM
Welwynnick's Avatar
2006 S600
I presume your car is left hand drive? That makes it a bit more difficult.
You will need to remove the left hand down pipes / cats, and probably the steering column from the rack (not from the bulkhead).
I would probably support the engine and lower the subframe to provide more access.
Nick
Old Apr 29, 2017 | 06:54 PM
ItalianJoe1's Avatar
2003 CL 600
Why would you say not to jack up the engine? If the mounts are unbolted, that's the only way to gain space for many operations on many benz vehicles...
Old Apr 30, 2017 | 05:58 AM
Welwynnick's Avatar
2006 S600
Originally Posted by Plutoe
This job is not as simple as some nubs will have you think--
Is everyone else a noob because they're not you?
Nick
