Custom springs for yellowspeed conversion
He will build me custom springs for my yellowspeed coilsprings set
what I need is the front and rear axle weight
If anyone has access to a weighing machine and could post these weights for a CL600 or CL65
Please mention if you have a spare wheel and tank level
I will post the specs and info here so you can make your own
the specs you get with yellowspeed is front 14kg/mm rear 10kg/mm (this is wrong) got this first from here https://mbworld.org/forums/cl55-amg-...tallation.html
My CL600 2003 recieved 20kg in the front and 16kg rear
this means they send out with several diferent springs
NEW info: CL500 kit comes with 14 front 16 rear
they can build up to 24kg/mm
thx
so now confirmed, yellowspeed send front 14 and rear 10 for CL500/cl55
and 20 front 16 rear for cl600/65
I had many option, but the spring factory told me the best thing would be to send my springs to him, he would calculate what the are in real (he said many are not acurate to the given specs)
then I might have to go up to 28 front 24 rear
my company is in the UK, there are many in the US too
I will be doing all this this summer but don't know when
means you should jump yours from 14 to 22 and 10 to 18
maybe 20-16
may I ask if when hooking up rear sway bars, was it much work ?
should have done the sway bar then
thx
but you can tell that all these arms have rubber, and 14 year old rubber........
you know what I mean
It was very cheap, at least here in Europe, I had choice of 4 different brands
and where to hook it up
when I did the front I had to buy some small parts from MB
<ith pics please
thx !
thx
