better coilsprings then yellowspeed
after another big search, here is the newest solution
camber adjustable
custom spring rates
dual springs
Just ordered a kit
Dual Springs × 1
Yes (Front + Rear) $100.00Rear Top Mount × 1
Pillowball Mount $60.00Front Top Mount × 1
Pillowball Mount $60.00Spring rates & Shock Valving × 1
Race/Hillclimb with Pro Race Valves : our expert team works with many pro drivers and champions up to GT3 racing level. We will choose the perfect circuit or hillclimb spring rates for you. $160.00CEIKA Type 1M
Coilover Kit for Mercedes-Benz CL-Class W215 (99~06) × 1$1,040.00
Subtotal $1,420.00
Shipping $0.00
Total $1,420.00 USD
https://ceika-store.com/products/cct1m427?locale=fr
Update Jan 3 2018
don't order here, they show camber adjustable top plates but they never made any for W215
to bad !
so so sad that it took all these years to start seeing these kits come out
if they had these ten years ago I wouldn't be sitting with a dead cl500 in storage that's now not worth reviving
PB Brakes:
http://pbbrakes.com/street-coilovers...nsion-kit.html
CNOcars:
https://cnocars.en.alibaba.com/product/60580690570-800605619/w220_amg_for_mercedes_s_class_w220_body_kit_220320 5113_2203202438_Arnott_NO_C_2242.html?spm=a2700.83 04367.prsea43447.3.3e0adee2PKgipg
FAT Chassis Technology:
https://www.alibaba.com/product-detail/for-mercedes-w220-S55-S65-AMG_60444488201.html?spm=a2700.7724857.2017115.97. 7d602382zcdEI7
AS Master:
http://www.airsuspensionmaster.com/coil-spring-conversion-kit-for-mercedes-w220-s-classc-224222032024382203205013-p00220p1.html
Some do remanufactured V12 coil packs:
http://www.airsuspensionmaster.com/m...-p00407p1.html
I'm quite tempted to dip my toe in the water there.
Nick
Just that I want harder damping and asked them about several changes
they do'nt even know what the kit they send you comes with
these other one in Hong Kong is used to make custom and drift or race suspensions
for regular drivers, or like you drive in the US, all straight, not fast, yellowspeed is ok
The W215/220 and subsequent models used multi-link front suspension, which has double-wishbone type geometry. Camber control is performed by the upper suspension link, not the suspension strut.
Nick
has anyone been able to install the Ceika coil overs? One of my strutmasters units are leaking after a few years so this would be a good opportunity to upgrade to something with more adjustability
AND
anybody have any developments with fitting the s430/s500 sway bar to the subframe of the cl500/cl600? I hear this is an easy swap
