CL-Class (W215) 2000-2006: CL 500, CL 600
left front speed sensor gone ...
Old Dec 21, 2017 | 01:20 PM
pmercury's Avatar
member
CL
I had Esp Abs warning coming on more and more
I replaced sensors and reluctor rings
I swapped ESP module with another extra I had
I tested the sensor plug above the wheel
I still have left front sensor giving 0 in Das Xentry
as warnings I have ESP ABS and tire pressure non functional warning
anyone has a Idea ? I am NOT good in electronics
thx !
Old Dec 21, 2017 | 07:16 PM
Welwynnick's Avatar
2006 S600
I had that once (of course).
The problem turned out to be an open circuit at the wiring connector where the wires go to outside the car.
Nick
Old Dec 22, 2017 | 01:45 AM
pmercury's Avatar
member
CL
Nick
ok thx a lot
its my left front wheel
the plug is ok, from the inside the engine, so back of the plug, you have a yellow and black tiny wire . you know where that goes ?
to the esp module, drivers fusebox ?
what you you do ?
Old Dec 22, 2017 | 01:13 PM
pmercury's Avatar
member
CL
Problem was the sensor position
I forgot that mounting this sensor is tricky
0.5mm to the left it doesn't work, 0.5mm to the right it doesn't work, shows 0KM/H on DAS
I took down the brake disc and caliper, hooked up DAS XENTRY
go in ESP, actual values
showing speeds of all 4 wheels
then ajust sensor, turn the axe with your hand to the left, and it shows 2.5 km/h if ok
done
Old Dec 23, 2017 | 05:08 AM
Welwynnick's Avatar
2006 S600
Good job Peter!
Do you think you would have found that without SDS?
Nick
Old Dec 23, 2017 | 05:22 AM
pmercury's Avatar
member
CL
Good job Peter!
Nick
Without Xentry Das ? yes
all the general Diag softwares like Autocom that you can get as a clone from Chine for 60$ will show speed sensor speeds
before I had Xentry I used that in the first weeks
But again, if you love working on your Benz, You MUST HAVE Xentry Das, EPC & WIS
thx a lot for your help again
Old Dec 23, 2017 | 09:37 AM
biker349's Avatar
cl600
again, great info. thanks
Old Dec 24, 2017 | 12:29 AM
ItalianJoe1's Avatar
2003 CL 600
Glad you got it sorted, I find often when it doesn't get fixed after a new sensor, it's an issue where the wires have been chewed by a rodent. Seen that on 3 or 4 cars already.
