ABC damages the gasket and flies out with a high pressure
Hi guys. Recently i had problem with my cl500 with power steering (PS). It works only if more than 1000rpm. So i bought defective abc pump with good PS section and i have replaced this section to my pump. I've assemble everything do the procedure with starting this pump and everything else what mercedes procedure want. After i start the engine and everything start working well. Abc section 190bar, power stering works very well. Car was working for 20 minutes then i switched off and wait for about 10-15 min. After i start engine again fluid get out with high preasure from the pump (between pump and this cylinder which is attached to the pump). So i dissasembly everything again replace orings (not original) and assemble again. And story was excactly the same - fluid on the floor). And again a replace with other orings (not original - bit diffrent than last one) and same story. So i have done the last time with used oring from difrent hose (original but used) and again same story.
Do you think its oring issue? 1st time i start engine car working very well abc and Ps. But after time i switch off and start again its blows with high preasurre. I already ordered new original gasket and hope this will help but maybe its something else? Maybe its something making to big preasurre and blows the weakest place? I already waste 7 liters fluid 2 day job and tones of nerves. Thank you
get a rebuilt one from rock auto they are about $250
Can it be oring fault?
That’s weird. Pump was good for 2 years and now it’s bad? I wasn’t detached because this thing happened but power steering failure. Maybe it’s true but I will try with oem oring and if it fail then I change pump.
Perhaps you'd let us know where you are from. This has proven to be useful information in the past.
biker349 (03-12-2018)
Hello again. I have solution. As I said I change rear part of pump from other working one. The problem was that the abc pump was from newer car and shape of this pump was slightly different. I have to cut a piece of it and everything was on it place. So problem solved
