CL-Class (W215) 2000-2006: CL 500, CL 600
CL600 Bi-Turbo exhaust sound upgrade?
Old Mar 14, 2018 | 01:24 PM
Dominik Kuček's Avatar
W211 E55 AMG Kompressor
Car is to quiet,any solution for that but without drone,i remove rear mufflers on E55 AMG Kompressor and drone is killing me,dont want the same on this one...
Old Mar 14, 2018 | 06:37 PM
tusabes's Avatar
Mercedes
it won't be the same , because the turbos are on the exhaust side and combined with the catalytic converters they muffle the sound . You can remove everything behind the catalytic converters with straight pipe on a 600
your kompressor doesn't muffle the sound at all
Old Mar 15, 2018 | 03:44 AM
So,straight pipe from catalysator to the tail pipes,without middle and rear mufflers,and it will be ok?
Old Mar 15, 2018 | 03:51 PM
tusabes's Avatar
Mercedes
Yes
Old Mar 16, 2018 | 07:59 PM
pmercury's Avatar
member
CL
you will get a whoo sound if you don't build a muffler
you should go to a custom exhaust specialist and let him build you some custom quit open muffler for the rear
that will avoid some of the whoo
but as tusabes said, you can try without, you might not be disturbed by the whoo
Old Mar 16, 2018 | 10:56 PM
ItalianJoe1's Avatar
2003 CL 600
The 600 exhaust is largely the same as the 65, except for added resonators. If you remove the resonators it sounds more aggressive without being loud or obnoxious, but everyone has a different interpretation of how loud is too loud.
