CL-Class (W215) 2000-2006: CL 500, CL 600
Hot air in cabin Steering shaft Boot fix
Old May 8, 2018 | 04:58 PM
pmercury's Avatar
member
CL
Exclamation Hot air in cabin Steering shaft Boot fix
You have hot air / engine smell in your cabin ?
maybe this is your problem
found lower part of Boot broken off
fix is not difficult but long if you have cats
without cats like me it was a piece of cake
the steering column and push the upper part into the cabin
unbolt tho upper bolts of the heat shield and bend a little to make space
unbolt the 3 bolts of the plate holding the boot from under the car
the plate moves then up in the cabin to free the boot
glide the new boot in from under he car
reverse
in the cabin
under the car
Old May 8, 2018 | 05:55 PM
renault12ts's Avatar
W215 CL500 2005
This happens on the w210 too...I wrapped fibreglass insulation around the shaft inside the split boot...still did the job 4 years later when I sold the car.
Old May 8, 2018 | 06:40 PM
pmercury's Avatar
member
CL
I discovered this when we removed CATS
I was wondering why that smell since 6 month's
boot is very cheap if you buy it aftermarket
Old May 9, 2018 | 10:22 AM
tusabes's Avatar
Mercedes
note also that removing cats will give your car an engine /exhaust smell too . Cats remove this smell
Old May 9, 2018 | 10:46 AM
pmercury's Avatar
member
CL
yes but this was windows closed before
