CL-Class (W215) 2000-2006: CL 500, CL 600
Stock boost
Old Jun 27, 2018 | 12:49 PM
Sojo40's Avatar
2006 CL600
Stock boost
What is the stock boost of a 04 CL600?
Is the ELM 327 odb2 scan reader accurate at giving the real boost and what should be set to, MAP, MAF or ALT to read most correctly?
Thanks.
Old Jun 27, 2018 | 03:31 PM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
MAP
Stock boost is 1 BAR - or approx 15 PSI
Old Jun 27, 2018 | 04:38 PM
pmercury's Avatar
member
CL
with some work you can get 19-21
Old Jun 29, 2018 | 02:16 AM
Sojo40's Avatar
2006 CL600
I finally got the BT elm 327 working with the correct measurement gauges. I have been curious of the numbers on everything and also thought my car seemed to have a bit more stock power then other, now i know why my boost is hitting very consistently to 15.5 to 17 psi boost. I seen others that would hey 14.5, 14.7 and that was suppose to be good. So I am good at my stock numbers now I know why my TC and ESP comes on so aggressively. It comes on so hard right after I hit full throttle at a dig I get thrown back in my seat but when it starts to spin the power cuts so fast and rear brakes hit so hard that I get thrown forward and would hit the steering wheel if not for the seat belt locking up. It happens so fast that it starts to hit again and push me back in my seat before I can pull my foot off the throttle. It was really startling the first few times I thought something broke. I had to get 295 width sticky tires to get enough grip to e en enjoy to power it can give.
I can't wait until I get my tune installed just waiting till I get my exhaust squared away which I am doing now.
Old Jun 29, 2018 | 02:53 AM
pmercury's Avatar
member
CL
I ordered a third OBD key this time wifi
the blue transparent version was mostly not connecting to my HU when needed
the bigger black version works little better but still slow
now a white WIFI version ........... supposed to work well and fast communication
Old Jun 29, 2018 | 02:55 AM
Most will be slow as it must use ISO 9141 which has a slow data rate.
Later cars (221/216) use 11bit can and logging is much faster.
Old Jul 2, 2018 | 01:11 AM
tusabes's Avatar
Mercedes
Which app are you using to show boost ? I have an iPhone and have the obd2 WiFi adapter
Old Jul 2, 2018 | 01:48 AM
pmercury's Avatar
member
CL
you can use xentry or Torque
Old Jul 8, 2018 | 02:49 AM
tusabes's Avatar
Mercedes
torque is android only , not iPhone
any good iPhone boost gauge app ?
Old Jul 8, 2018 | 03:18 AM
pmercury's Avatar
member
CL
DashCommand
Old Jul 9, 2018 | 11:27 AM
Geraldius's Avatar
'15 GLK350, '05 CL65 AMG, '04 C320 4matic
Torque has an iPhone app version, but it is WiFi and requires a WiFi version of the OBDII dongle, like this one from BAFX:
Amazon Amazon
