CL-Class (W215) 2000-2006: CL 500, CL 600
SRS warning light
Old Jul 26, 2018 | 12:43 PM
JHM's Avatar
JHM
2004 CL 600
Angry SRS warning light
I was pulling out of a tight driveway (1mph) my passenger front tire went over the curb (about 4" tall) as I heard the clunk my SRS light went on in the speedometer area of the instrument panel. When I hit the R button it goes away except for a small red SRS (left side) When I restart the car the big red SRS appears. What can be done, how could a bump cause the seat belt restraint system to malfunction? Thanks for any insight. John
Old Jul 27, 2018 | 01:58 PM
tusabes's Avatar
Mercedes
SRS does not mean seat belt restraint it’s supplemental restraint system (aka airbags and belts)
you probably damaged an airbag sensor when going over the curb
Old Jul 28, 2018 | 08:47 AM
JHM's Avatar
JHM
2004 CL 600
Thanks for the info, is the airbag sensor something I can replace or do I need a mechanic shop. Oddly enough, I've had the car for two and a half years and the only repair is brakes done by a good shop but they don't specialize in MB
Old Jul 29, 2018 | 01:02 AM
tusabes's Avatar
Mercedes
airbag sensors should be replaced by a shop because if you touch something wrong you can pop all 8 interior bags and your car will be a total loss . You need to disconnect the battery for at least an hour and must know exactly what to do
Old Jul 29, 2018 | 01:09 AM
ItalianJoe1's Avatar
2003 CL 600
Have it diagnosed and see what failed, the light being on means there is a code for something that's damaged or not working. Might be simple, might be expensive. Have it scanned with a real SDS system.
