CL-Class (W215) 2000-2006: CL 500, CL 600
Intermitten Limp Mode
Old Jul 31, 2018 | 03:51 PM
AustinV12's Avatar
CL600
'01 CL600 had one good day (60 miles) after replacing Crankshaft Sensor and Harness, and both Camshaft Sensors and their Harnesses. Prior that it had a no-start issue, and all three of those sensors were throwing codes. Now I have to start and restart the car 2-3 times to get it out of Limp Mode. Once out of Limp Mode, it runs great. Fabulous, even. So ... what am I experiencing? Do I just need to put more miles on it and let the machine self-learn? Are the sensors I put in not exactly what the car wants/needs?
I disconnected/reconnected the battery to see if that helped. That set off a slew of codes that eventually cleared (ESP, BAS, ABS...). After this last test drive I'm down to only the right Camshaft sensor showing an error.
Another interesting thing ... if I do not erase the code(s), everything runs fine. If I erase the code(s), it takes several restarts to get it out of Limp Mode.
Any experiences with this will be appreciated.
Old Aug 1, 2018 | 05:23 AM
tusabes's Avatar
Mercedes
yes a reset can trigger limp mode
just keep driving it to let it re learn
Old Aug 4, 2018 | 06:25 PM
AustinV12's Avatar
CL600
Still getting Limp Mode about every 3-4 starts. 120 miles since clearing all codes. On the brighter side, the car passed Texas safety and emissions inspections, today.
Still thinking the car is working through some type of prolonged relearn. If it goes into Limp Mode, it comes right back out by stopping and restarting the engine. Tough one to figure out.
