CL-Class (W215) 2000-2006: CL 500, CL 600
AC not working
Old Aug 12, 2018 | 12:20 PM
kenhartz's Avatar
1986 560 SEC
AC not working
my AC stopped working sometime this past fall. I finally got around to attempting to fix it. In checking the internal diagnostics there was a fault code for a evaporator temperature sensor. I replace the sensor, now there’s no fault codes, but the system still blows warm air. I hooked up my AC manifold gauges and the low side is running very high approximately 100 to 120 pounds, the high side is running At about 110 pounds. I believe I have a clutchless compressor, and it is spinning. My thought is that the compressor is not compressing. Any thoughts? Thanks
Old Aug 12, 2018 | 03:55 PM
pmercury's Avatar
member
CL
You might not be able to restart your ac without Xentry DAS
I worked a lot on my ac and you need to delete all fault codes with DAS to get it start up again
do you see a red dot on your ac dash ?
Old Aug 12, 2018 | 07:23 PM
kenhartz's Avatar
1986 560 SEC
I have an icarsoft MBII reader. I think I was able to clear the codes, but now that I think, I may have been having trouble reading the diagnostic codes. I think I was able to monitor/stream values. The MB II is supposed to read the values, but maybe I’m doing something wrong?? I’ll have to try again and see. I cleared the codes in the hidden menus for the HVAC diagnostics in the HVAC control console.
That seems to make sense, as it’s highly unlikely that multiple parts fail simultaneously, but who knows. I would love to fix this ASAP, as the weather here in NJ has been brutally humid!
thanks
ken
Old Aug 12, 2018 | 07:26 PM
kenhartz's Avatar
1986 560 SEC
also, I don’t remember seeing a red dot on the dash. But I’ll look
Old Aug 13, 2018 | 12:27 AM
pmercury's Avatar
member
CL
the red dot is AC OFF
Old Aug 13, 2018 | 02:26 AM
kenhartz's Avatar
1986 560 SEC
the ac off was lit prior to installation of the evaporator temp sensor, once code was cleared (through the onboard diagnostics) the light went out after restarting the car. But no, ac yet.
Old Aug 13, 2018 | 03:42 AM
pmercury's Avatar
member
CL
mmm then it is not the ecu security keeping your compressor shut off
not good news
Old Aug 13, 2018 | 10:47 AM
kenhartz's Avatar
1986 560 SEC
not good news
i just read what I replied, I had a typo, ac off light was lit, then after after installation of sensor, I cleared code, light went out, and no more codes. But I think you got the jist of what I was saying by your response. Yeah, I’m thinking it’s not good. I’m thinking compressor, but given this is one of the clutchless ones, I thought maybe some valve on it or something?? Or am I just doing something stupid and not realizing??? Thanks
Old Aug 13, 2018 | 11:15 AM
pmercury's Avatar
member
CL
get someone hook up Xentry DAS
there you will find the problem
Old Aug 14, 2018 | 12:22 AM
kenhartz's Avatar
1986 560 SEC
Mia that the star diagnostic program? Is the carsoft MB II not sufficient?? Thanks
Old Aug 14, 2018 | 02:58 AM
pmercury's Avatar
member
CL
you will never have the parameters we have in Das Developer in any other soft
I did not say to go to MB
just find someone with a C4 and Xentry
Old Aug 14, 2018 | 10:51 AM
kenhartz's Avatar
1986 560 SEC
gotcha, I’ll sniff around and see what I can find
