215 CD changer help
amplifier is OK. Any ideas? It is also irritating that the WIS doesn't easily give you any troubleshooting references in the entire file. Has someone located information in the workshop manual to at least test the changer?
The problem is the CD gets stuck somehow, once I had to remove the unite and dismantle it to get the cd out, but tapping usually works.
If when you try to eject you do not hear the mechanism, you might be screwed...
