CL-Class (W215) 2000-2006: CL 500, CL 600
Very shaky idle
Old Jan 15, 2020 | 06:56 PM
MartinWake's Avatar
CL55
Very shaky idle
Hello everyone I have a 2002 CL500 with 170k Miles and when I first got it this didnt happen but now at idle when its up to temp it shakes like crazy and when letting off the brake to creep forward you can feel it back and fourth. I replaced all the spark plugs, the coils are good and I have all my vacuum lines connected. Does anyone know what the problem could be? I will attach a video so you can see the rpm it idles at and ill move forward a little you can look at the mirror and you can see the vibration a bit. Thanks!
Video: https://drive.google.com/file/d/14Tg...ew?usp=sharing
I pulled the codes with my OBD 2 scanner (I have no cats)
p0106
p0305
p0307
p0410
p0432
p0422
p0300
The misfire codes could be from before I changed the spark plugs
Old Jan 16, 2020 | 07:32 PM
MartinWake's Avatar
CL55
Old Jan 19, 2020 | 05:47 PM
Fried Chicken's Avatar
2005 S500 Designo
Did you take out both cats or only the rear cats? It sounds like you took out both, so the rear O2 sensor could be a bit pissy and cause the engine to run lean. What are your temps like? What did your spark plugs look like when you pulled them out?
It sounds like your replaced your spark plugs and confirmed the coils are good. Did you clear the codes after doing so? Does the shakiness persist after clearing the codes? How long before the CEL comes back on?
Old Jan 22, 2020 | 01:11 PM
MartinWake's Avatar
CL55
The spark plugs looked okay but I had just got the car so I dont know how long the previous owner had them installed, the temps look fine at idle while riding they go down a bit and I dont know what the CEL is
Old Jan 22, 2020 | 04:53 PM
2005 S500 Designo
CEL = Check Engine Light.
If they looked fine they should be fine.
Did you take out both cats or just the rear cats?
Old Jan 23, 2020 | 06:57 PM
MartinWake's Avatar
CL55
All the cats are out and the CEL is prob on but the light is dead
Old Feb 9, 2020 | 08:24 PM
MartinWake's Avatar
CL55
It only happens when engine is up to temp
Old Feb 17, 2020 | 03:47 PM
MartinWake's Avatar
CL55
fixed by using the A/C for a while
Old May 10, 2020 | 01:25 PM
ctravis595's Avatar
2002 CL500 to CL55 conversion
secondary o2 sensors should have no real effect on running Fuel mixture
rear o2 sensors are only there to test if the catalytic converters are working
to answer the original post, a shaky idle is most often caused by a loose vacuum hose.
the m113 engine has a notoriously annoying hidden vacuum hose underneath of the intake manifold which can fail, once it fails it cannot be properly repaired because there is no hose fitting, the hose instead feeds into the intake. They say the proper fix is to replace the manifold
but sometimes also caused by an overly lean or overly rich mixture .
this can be a lazy maf sensor, primary o2 sensors failing, clogged exhaust, bad fuel, clogged injectors, clogged air filters
Old May 10, 2020 | 01:28 PM
ctravis595's Avatar
There is a technical bulletin from 2001 that states certain ecu’s built in 2001 need to be replaced due to a lean idling condition , you can see if your ecu is on the list by matching up the part number on the ecu
Old May 10, 2020 | 02:02 PM
pmercury's Avatar
member
CL
always start by upgrading the first with the corrected firmware
