CL-Class (W215) 2000-2006: CL 500, CL 600
Can I put CL55 or CL65 ABC struts on my CL600?
Old Jan 23, 2020 | 11:59 PM
Fried Chicken's Avatar
2005 S500 Designo
I have a feeling the enormous power of the renntech tune is wreaking havoc on my rear end.
It's so powerful; like thor's mighty hammer commands the sky, the Renntech nuclear missile commands the road.
Unfortunately, I think it's destroying my ABC struts in the back; at least the bushings at the top. The car jumps and wobbles going around turns while slightly (like normal car slightly) accelerating. Also at highway speeds, there is a shake that comes from the rear end that I was able to fix on the S500 by replacing the ABC struts.
Old Jan 24, 2020 | 11:53 AM
pmercury's Avatar
member
CL
The torque does that I guess
did you add limited-slip differential ?
if not get it ! I love it and helps a lot
Old Jan 24, 2020 | 07:31 PM
2005 S500 Designo
It has the full Renntech tune:
Engine, Intercooler, Transmission, and LSD.
Question remains: do the CL65 struts fit on the CL600?
Old Jan 24, 2020 | 09:34 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Should not be an issue.
Old Jan 25, 2020 | 04:53 AM
pmercury's Avatar
member
CL
Hey, I never searched but did we get a final word with proof on the difference between the AMG and Non-Amg ABC struts ? or is it just a relabel story again ..?
https://mbworld.org/forums/cl55-amg-...uspension.html
Old Jan 25, 2020 | 11:56 AM
BlownV8's Avatar
Probably a relabeled strut but there may he some slight internal valve difference. Knowing MB, there is no difference and the suspension difference is done through programming. Either way, should work fine.
Old Jan 26, 2020 | 07:53 PM
BlownV8's Avatar
The part numbers are different so give Arnott a call to make sure. Will it work, yes. Will it work like the other shocks? Not 100% certain.
Old Jan 27, 2020 | 08:49 PM
C280 Sport's Avatar
MB’s of all kinds.
I would assume the 500, 600, 55 and 65 all the same strut. Not sure why MB would make a new one for each model.
Old Jan 27, 2020 | 08:52 PM
BlownV8's Avatar
The 500 and 600 are the same part number while the 55/65 are also the same. There must be a difference but I have no idea what it is. Could be firmer valving or internal springs. I've also read the 55/600 could be used interchangeably. With that said, I sent a visitor message to ArnottDoug in hopes he would respond.
Old Jan 27, 2020 | 11:57 PM
2005 S500 Designo
Thanks for that; looking forward to the reply
