CL-Class (W215) 2000-2006: CL 500, CL 600
Power steering rack
Old May 31, 2020 | 04:57 PM
HopefullyE63's Avatar
SL55 CL600 and 335D (rip flood) 325ci
Power steering rack
Hi guys. Anyone use a reman steering rack part from Detroit axle? My car feels super loose and making bad noises. When I took the under body panes off I saw rubber material that looked like some kind of “boot”. The boot that covers the tie rod is dry and not really protecting anything.
how do I know if I only need bushings?
Please share success stories and where you sourced the part of you did it. Conversely what did your indie charge for this?
Old Jun 2, 2020 | 08:30 PM
argilla11's Avatar
2003 CL600
Assuming you're talking about the rack bellow, you can find it at the dealer or on ebay. They aren't hard to replace. I would recommend having your indie shake down the front of the car. It's likely your inner tie rods have worn from contamination. The lower ball joins are a common failure and would also cause looseness, clunking and squeaking.
