CL-Class (W215) 2000-2006: CL 500, CL 600
How to program used Keyless go cards
Old Jul 14, 2020 | 11:40 AM
a54067's Avatar
C215 CL 600 2003
Hello
Sorry for posting again. I just bought my 2003 CL 600 and have multiple issues.
My car did not come with the 2 KG cards and I have now bought two used cards from a scrapped car.
Is it possible in someway to program these for my car with SDS or simular or mayby without?
What I can remember these cards dont come preprogrammed when ordered but must be programmed by dealershop.
I thereby thought it might actually be possible to reuse KG cards for another car.
I have also read the thread about the KG Key upgrade from 2003 to the intergrated keys like in 2004- and that sounds really really cool, but first I really would like it to work with cards. I like the cards.
Pardon my bad english
David in Sweden
Old Jul 14, 2020 | 02:38 PM
pmercury's Avatar
member
CL
https://mbworld.org/forums/sl-class-...ml#post8106070
Old Jul 14, 2020 | 03:50 PM
a54067's Avatar
C215 CL 600 2003
Thank you. Most interesting thread.
Unfortunately I dont have the original KG cards and can thereby not read data or resolder any chips.
I will examine this a little further this weekend, but if I understand right for now there is no known way to reprogram a used KG card?
Thank you once again.
Old Jul 14, 2020 | 04:20 PM
pmercury's Avatar
member
CL
my pleasure
not that I have seen no
just swap the keyless go module and move to keyless go on key
Old Jul 15, 2020 | 07:51 AM
a54067's Avatar
C215 CL 600 2003
Originally Posted by pmercury
my pleasure
This might be a dumb question, but if I put the KG module from the car from I bought the used KG cards from in my car. Would that possibly work?
Old Jul 15, 2020 | 08:27 AM
pmercury's Avatar
member
CL
nope
the keyless go module does not contain the security
the Eis does
only solution would be to buy a Eis + cards + shifter + engine ecu
but then you will have the wrong VIN showing up in diagnostics
Old Jul 15, 2020 | 09:21 AM
a54067's Avatar
C215 CL 600 2003
nope
the Eis does
Ok, but then I have to consider the upgrade instead. It seems really cool.
I have som KG issues with drivers door and gearknob that dont react. Maybe bad resistor inside.
Only passenger door and trunk react at all and react with "chipcard not recognized".
I will although try some programming this weekend with the used KG cards.
Thank you for clearing this all out.
/David
Old Jul 15, 2020 | 12:15 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
...but first I really would like it to work with cards. I like the cards.
I like the cards too, and before I discovered that the SL55 I had just bought had them, I investigated the possibility of acquiring the Keyless Go cards. From my research I can confirm everything that has been written here about this, so unfortunately, I don't believe it is plausible for your vehicle to ever use cards.
Old Jul 15, 2020 | 01:17 PM
pmercury's Avatar
member
CL
/David
can be a antenna issue
In Xentry you have plenty of pages to verify antennas and reception
Old Jul 20, 2020 | 04:21 PM
a54067's Avatar
C215 CL 600 2003
/David
I tried som programming this weekend, but without luck.
I also can confirm that this case is closed as for now.
Old Jul 20, 2020 | 05:26 PM
pmercury's Avatar
member
CL
Told you, if you have keyless go installed and no cards, go for keyless go in key conversion
need just a later keyless go module and order a key from MB
