CL-Class (W215) 2000-2006: CL 500, CL 600
Head unit upgrade?
Old Dec 18, 2020 | 03:51 PM
Urbansq1's Avatar
01 sl500
Head unit upgrade?
I have a 01 cl55. It has this unit. I have been been unable to find any sort of dash kit to fit a new deck. Anyway I can ad an aux input to this?
Old Dec 19, 2020 | 05:43 AM
renault12ts's Avatar
W215 CL500 2005
I don't know about adding an aux, someone else will...but, to fit a new head unit you will need first to find the fascelift wood panel. That means you will need the switches too...and that's not so straiught forward.
Old Dec 21, 2020 | 10:02 AM
Urbansq1's Avatar
01 sl500
From what I have herd about swapping the switches is that its can bus switches...
Old Dec 21, 2020 | 04:36 PM
BenzNinja's Avatar
Former Vendor
https://mbworld.org/forums/cl-class-...-retrofit.html
more info about command swap
https://mbworld.org/forums/s-class-w...upgrade-4.html
https://www.benzworld.org/forums/aud...and-2-5-a.html
https://mbworld.org/forums/s-class-w...s55-amg-5.html
Old Jan 14, 2021 | 04:38 PM
JRAZ305's Avatar
W215
I’ve thought about doing the swap problem is the communication between abc and other buttons is not the same on the first w215. When they changed the command to the modern one. The language changed so u can turn a feature on but they won’t respond after that u would have to turn off the car off.
what I’m thinking about doing is getting one of those 10 inch android displays. That would cover the entire 2.5 din hole and modernize the dash. Only thing that sucks. Is those radios don’t do. HD radio. But u got android on board. And access to Pandora and other apps so HD radio is not needed.
Old Jan 14, 2021 | 04:41 PM
JRAZ305's Avatar
W215
Ya digg
